    I can't use my applications normally after receiving calls with my Samsung Galaxy S9. When I open some application after the call has ended it stays on about 1-5 seconds and then the phone returns to home screen. I've noticed this happening a couple of times after the latest software update. I've tried to close all the running applications and even reboot the phone but it doesn't help. It will stop doing this after a while so I'm not really sure what is causing this or what might be fix for this problem. Has anyone else noticed a same kind of problem?
    03-06-2019 06:08 AM
  1. Galaxy s9 only and 2019 Chevrolet mylink Cant answer calls
    Last Post: 03-16-2019, 10:22 AM
  2. Is it possible for my Galaxy s8 to uninstall apps by itself
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-07-2019, 10:26 AM
  3. How to videos
    By tgseaver in forum Samsung Galaxy S10 & S10+
    Last Post: 03-07-2019, 05:17 AM
  4. Find update for Galaxy TAB 2 7.0 GT-P3100 to Android 5.1 (Lollipop)
    Last Post: 03-06-2019, 05:33 PM
  5. why wont my hudl after factory reset only go to checking for updates
    Last Post: 03-06-2019, 06:01 AM
