1. Monee_121's Avatar
    S9 Running Pie. Since Pie update, lock screen music controls have stopped working. They are visible with all music apps (Spotify, Samsung Music, Pandora, Play Music) both on the lock screen and in the notification shade. All notifications are set to ON, and I haven't changed anything.
    Also while my phone is locked I cannot use headphones double tap nor my car's steering wheel track controls, but they all work when the music app itself is open. I can't figure it out and it's killing me! Please help...
    Chloe Jenkins likes this.
    03-06-2019 05:29 PM
  2. Chloe Jenkins's Avatar
    Just to add to this, I'm using an S8+ and I'm having the same issue.
    03-12-2019 02:22 PM
  3. pontiac005's Avatar
    Running Pie on an S9+ and just tried it using Spotify. It was working fine on my phone.
    03-12-2019 03:17 PM
  4. JulioM's Avatar
    I'm having a similar issue. I am on a Note 9 with the Pie update. After installing the update, I did a factory reset to start fresh. Not sure if there's a setting that controls this, but I can't find anything. Volume controls work when the screen is locked but play/pause and skipping tracks does not work in certain situations that I have not figured out. Same issue with wired or wireless headphones.
    It seems like it's just Spotify, but I'm not sure. If I leave Spotify playing in the background while the screen is locked and then try to pause it, it will not pause. Sometimes it's instant, and sometimes it stops working after playing for awhile. I have tried it with Pandora and do not have issues with it.
    Another glitch is that sometimes my music will stop streaming and I'll lose my spot in podcasts using Spotify. I am willing to bet that it's an overall glitch with Spotify.
    03-12-2019 04:47 PM
  5. Monee_121's Avatar
    Same here with Spotify stopping randomly and restarting. I now think it's more of a Spotify issue not fully compatible with Pie? Not sure.
    03-12-2019 05:13 PM
  6. chanchan05's Avatar
    I had this, but it was fixed with the Spotify update last night for me.
    03-12-2019 05:21 PM
  7. Monee_121's Avatar
    Finally fixed it! Got the latest update 8.4.96.953 and then had to go to Settings>Device Care>Battery. Under Optimization, Spotify was listed to put to sleep immediately. I turned this option and all works just fine! WHEW! lol
    Trey2019 likes this.
    03-12-2019 06:10 PM
  8. Trey2019's Avatar
    Thank you for posting Monee_121, that did the trick!!
    Monee_121 likes this.
    03-14-2019 04:55 PM
  9. Monee_121's Avatar
    Glad I could help!!
    03-14-2019 10:07 PM
  10. christiannnn_m's Avatar
    Just found a fix to this and reported it to spotify so hopefully they can fix it permanently. What worked for me is I needed to uninstall the Google Play Music app since it seems to have a compatibility issue with spotify.
    04-15-2019 09:55 AM
  11. Punksnotdead's Avatar
    Just updated to pie today and immediately had issues. Went through forums, tried every option out there. What finally worked is resetting my phone. Hope you all have luck with the spotify problem.
    04-21-2019 07:17 PM
  1. Share your home screen setups.
    By durandetto in forum Samsung Galaxy S10 & S10+
    Last Post: 04-04-2021, 10:28 PM
  2. hould I do when it's saying my fingerprint is not recognized
    Last Post: 03-07-2019, 09:24 PM
  3. Replies: 1
    Last Post: 03-07-2019, 09:11 PM
  4. S9 text not showing up on car blue tooth
    Last Post: 03-06-2019, 03:12 PM
  5. Edit songs in Google play music
    Last Post: 03-06-2019, 02:34 PM
