1. LRMCforlife's Avatar
    Just started Sunday I believe. I started getting pop-up ads on my home screen, on any app I'm running. I can't do anything until I X out of the ad.
    I have searched the net on this. I also believe it's ad choice pop ups. Most of them say it somewhere in a corner of the pop up. I have deleted apps I thought could be it. I have gone in play store to see what was last thing running.
    I have downloaded, paid for and ran Kaspersky. I even got blokada 3.7, even did malwarebytes.
    Nothing is finding it.
    Hopefully someone can help. I have link to the photos of what I'm seeing. Looks like it happens in play store. But if you look while on Samsung internet it's on the bottom in 1 photo. Then the top in another.. Never seen those ads there before.
    Thanks.
    https://photos.app.goo.gl/UtJLot47bxMh92cy8
    03-19-2019 07:32 AM
  2. Javier P's Avatar
    Welcome to the forums. See if this helps.
    https://forums.androidcentral.com/sh...d.php?t=901497
    LRMCforlife likes this.
    03-19-2019 07:53 AM
  3. LRMCforlife's Avatar
    Thanks, I will follow that.
    Update:
    Thanks, for the help. So far it looks like it was Note pad 2018. Not sure when or how I got it. But I know I've had it for awhile. There was a bunch of updates I had to do. I know that was one of them. So it must have been in the update. Either way thanks for the walk through. Appreciate your help!!
    Javier P likes this.
    03-19-2019 10:00 AM
  4. Javier P's Avatar
    Update:
    Excellent! Glad it helped and thanks for the follow up, it'll be very helpful for other members with a similar issue.
    03-19-2019 01:56 PM
  1. S8 new update changed my whole settings. Please help!
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-23-2019, 11:25 PM
  2. Replies: 1
    Last Post: 03-19-2019, 01:24 PM
  3. Group message pop up
    By scott.doyle@outlook.com in forum Samsung Galaxy S10 & S10+
    Last Post: 03-19-2019, 11:33 AM
  4. S8 new update changed my whole settings. Please help!
    Last Post: 03-19-2019, 05:39 AM
  5. Replies: 0
    Last Post: 03-19-2019, 04:26 AM
