1. bradkusik's Avatar
    Does anyone know why the fingerprint scanner on my S9+ will intermittently not work? And by intermittently I mean it hardly works at all.
    It will vibrate and attempt to scan, but after 5 attempts the phone will require the use of the pattern to unlock the phone. Of course, if I setup a new fingerprint in settings, then it will work just fine. Is it simply a matter of the scanner not being very precise when your finger is cold or dry or basically different in some way then when I initially set it up?
    Thanks!
    04-05-2019 06:01 AM
  2. belodion's Avatar
    Moved to S9.
    04-05-2019 07:20 AM
  3. lucianus_luciferus's Avatar
    You can try saving the same finger twice to increase the successful scan chances.
    pontiac005 likes this.
    04-05-2019 02:22 PM
  4. blackops1125's Avatar
    Yea that's what I did
    04-07-2019 08:28 PM
  1. Auto rotate gone on s9 ?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 06-11-2019, 06:08 PM
  2. Replies: 3
    Last Post: 04-05-2019, 09:21 AM
  3. Replies: 1
    Last Post: 04-05-2019, 04:51 AM
  4. Guy 3d printed fingerprint and unlocked s10
    By NIZMOZ44 in forum Samsung Galaxy S10 & S10+
    Last Post: 04-04-2019, 09:25 AM
  5. Auto rotate gone on s9 ?
    Last Post: 04-04-2019, 05:48 AM
