1. missy8787's Avatar
    For some reason when I receive txts or game or email notifications the sound doesnt work but when I get phone calls the sound works. If I go to sounds they dont play back either. I tried restarting my phone and checked that all my sounds r on and they r idk y they stopped
    04-06-2019 10:08 PM
  2. bbgpsuser's Avatar
    Have you checked the volume levels? There are different controls for phone calls, media, notifications, etc.
    Visit Settings -> "Sounds and vibration" -> Volume to adjust each.
    04-06-2019 11:12 PM
  3. missy8787's Avatar
    Yes I have everything's set the same. What's weird is when I get a txt it vibrates and if it's a notification its silent nothing.
    04-07-2019 07:25 AM
  4. missy8787's Avatar
    Also it doesnt make a sound when plugged in anymore and I cant preview sounds
    04-07-2019 07:55 AM
  5. bbgpsuser's Avatar
    Have you checked in Settings -> "Sounds and vibration" that "Notification sounds" is set to a sound?
    Also have you checked Settings -> Notifications and checked that the appropriate sound is chosen for the txt application?
    04-07-2019 07:57 AM
  6. missy8787's Avatar
    Yep did all that:/
    04-07-2019 10:31 AM
  7. missy8787's Avatar
    Out of the blue everything started working again thanks for the replies
    04-07-2019 11:41 AM
  1. Android Auto not working
    By Tim98TA in forum Android Auto
    Last Post: 04-16-2019, 07:12 PM
  2. My Galaxy Note 8's wifi not working after security update
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 04-07-2019, 03:01 AM
  3. I have not gotten Pie on my Sprint Note8 yet
    Last Post: 04-06-2019, 09:53 PM
  4. Nano glass s10, update? Does it work?
    Last Post: 04-06-2019, 08:06 PM
  5. So, I am a Lil confused: should I get rid of it or not???
    Last Post: 04-06-2019, 06:48 PM
