1. robynmae's Avatar
    With my S9+ I have no option to change the homescreen font color or Icon font color myself. When using themes all areas of my phone automatically switch the color of fonts but my homescreen & icon letters, they all stay white.
    I have changed icons, themes, purchased fonts, all these numerous times to no avail.
    Launchers I use are Evie & Touchwiz.
    Has anyone else had/have this issue & found a solution for the S9+?
    04-12-2019 08:04 PM
  2. Mojave's Avatar
    I use Nova Launcher Prime and can change my homescreen font icon color to anything I want. I hope I understood you correctly.
    04-13-2019 05:52 AM
  3. krisqz's Avatar
    A stretch, but do you have 'lock layout' enabled in Home screen settings in default launcher?
    04-13-2019 07:55 AM
  4. robynmae's Avatar
    Thank you both, I finally have it figured out.....it is Evie Launcher.
    Next time I have an issue I will definitely be posting on here.
    04-13-2019 08:37 AM
  1. Why does a lighr come on when i receive a call
    Last Post: 04-12-2019, 09:06 PM
  2. Replies: 1
    Last Post: 04-12-2019, 09:03 PM
  3. homescreen fonts not changing color
    Last Post: 04-12-2019, 08:03 PM
  4. Unread texts on Note 9?
    Last Post: 04-12-2019, 07:10 PM
  5. Fonts
    By PitCarver in forum LG V40
    Last Post: 04-12-2019, 07:03 PM
