1. kikbxr1969's Avatar
    So, not sure when it started (I think maybe after using Good Lock to change "Panel Settings" color in Quick-Panel Star). However, now the pop-ups I get are so faint that they are barely readable. I cannot seem to find a setting to get them back? I am sure that there has to be an opacity setting somewhere that I am missing. Anyone got any idea?
    Text behind volume that popped up while trying to screen shot is what I am referring to.
    Notification Visibility/ Settings?-popup.jpg
    04-19-2019 10:30 AM
  2. bbgpsuser's Avatar
    Just a thought, do you have a theme applied?
    04-19-2019 10:37 AM
  3. kikbxr1969's Avatar
    I have the default theme with a black wallpaper (Tried reapplying the default theme - but that made no difference)
    It really seems like when I used Good Lock to change the color theme is when it happened. But, there is no revert to default there.
    04-19-2019 10:52 AM
  4. kikbxr1969's Avatar
    Never mind, I found it. Apparently, it WAS QuickStar on GoodLock
    And, although you cannot revert, you can pick a panel setting with a different background that has a visible popup. Then, you can change some of the colors.
    Would have been nice if they had a restore defaults option. Oh well.
    04-19-2019 11:18 AM
  1. Camt set my alarm it says no alarms,how can i reset
    Last Post: 04-19-2019, 02:35 PM
  2. I get an "email sign-in failed" notification even though I haven't been trying to sign in
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 04-19-2019, 02:05 PM
  3. Wrong notification sound
    By Android Central Question in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 04-19-2019, 07:40 AM
  4. Wrong notification sound
  5. WhatsApp Weird notification
    By Android Central Question in forum WhatsApp for Android
    Last Post: 04-19-2019, 01:52 AM
