1. Brent Michael's Avatar
    So the other night my wife's and my s9s got the April security update and since then we can't do split screen by holding the recent apps button. We have to tap it, tap the apps icon above the desired app and select "view in split-screen" is there any way to go back to holding the button. We're on T-mobile and both have the nav bar up
    04-21-2019 10:56 AM
  2. mustang7757's Avatar
    If you install Good Lock App you can do split screen little more easier through recent apps .
    04-21-2019 11:28 AM
  3. ckfilmstar's Avatar
    YouTube vid.
    04-21-2019 01:04 PM
  4. ckfilmstar's Avatar
    I'm using split screen right now while typing this lol
    04-21-2019 01:05 PM
  5. Brent Michael's Avatar
    YouTube vid.
    It was working after the pie update but not after the April security update
    04-21-2019 01:06 PM
  6. Brent Michael's Avatar
    I can use it I just can't get there by holding the multi-tasking button
    04-21-2019 01:07 PM
  7. ckfilmstar's Avatar
    Maybe it doesn't work for all apps
    04-21-2019 02:44 PM
  8. mustang7757's Avatar
    That is true wont for all apps , I give you the Good Lock app because you can put recent apps in list view and little round icon on the bottom you tap to split screen from there just drag
    Multi-window not working from holding recent apps-screenshot_20190421-162107_task-20changer.jpeg
    04-21-2019 04:22 PM
  1. Unwanted audio upload from phone to Play Music
    Last Post: 04-22-2019, 07:43 AM
  2. Replies: 2
    Last Post: 04-21-2019, 05:44 PM
  3. Why popup's to install commercale app?
    Last Post: 04-21-2019, 02:28 PM
  4. Why some app are not movable from internal to external memory of Samsung S7
    Last Post: 04-21-2019, 08:35 AM
  5. My Galaxy S9 will not Update its software... I can't seem to get it to work
    By Tami Pruett in forum General Help and How To
    Last Post: 04-21-2019, 02:30 AM
