K kmatwill New member Mar 15, 2014 1 0 0 Visit site May 10, 2019 #1 Hi, Is there any way to force 3G on verizon s9+? In mobile networks there are only LTE options. thanks
blackops1125 Advisor Mar 19, 2011 1,037 184 0 Visit site May 12, 2019 #2 Use 4G switcher from play store. You can force your phone to use 4G,3G,1X or none of the above.
joeldf Well-known member Dec 19, 2011 1,160 525 113 Visit site May 14, 2019 #3 kmatwill said: Hi, Is there any way to force 3G on verizon s9+? In mobile networks there are only LTE options. thanks Click to expand... Won't matter in 7 months. Verizon is shutting down its 3G and CDMA 1X (2G) networks at the end of this year. They are trying to keep people off those networks as much as possible for that reason.
