1. Zafferd's Avatar
    Hi,
    I can't figure out how to choose camera RAW as the format to save my pics in Galaxy S9+ with the Pro setting. There is no choice for it under camera > settings > Rear Picture Size like there is in the S9. Can someone tell me how to choose camera RAW in the S9+? Thanks.
    Zaffer
    05-10-2019 09:39 PM
  2. B. Diddy's Avatar
    I moved this from the ancient Galaxy S forum to the S9+ forum.
    05-11-2019 12:18 AM
  3. Zafferd's Avatar
    Thanks B Diddy. My Bad.
    05-11-2019 10:21 AM
  4. B. Diddy's Avatar
    No problem -- just want to make sure your post doesn't get lost in the nether reaches of history!
    05-11-2019 11:27 PM
  5. Deepcuts's Avatar
    B. Diddy likes this.
    05-13-2019 02:43 AM
  6. pontiac005's Avatar
    Hi,
    Zaffer
    Did the suggestion work?
    05-18-2019 02:10 AM
  1. how do you exit bootloader mode on an motorala?
    Last Post: 05-11-2019, 05:39 PM
  2. Replies: 1
    Last Post: 05-11-2019, 12:20 AM
  3. How do you get rid of continuous ads on screen
    Last Post: 05-11-2019, 12:14 AM
  4. How to limit annoying Facebook Notifications?
    By Android Central Question in forum Android Apps
    Last Post: 05-10-2019, 07:21 PM
