1. MrsNorris428's Avatar
    Am I crazy? I'm debating about trading my S9+ for a pixel 3a. I understand what I'd be "losing" as far as the specs are concerned but I'm really compelled by the price...and color. I wise T-mobile had the purple-ish one, otherwise I'd of made the jump by now.
    05-13-2019 04:38 PM
  2. missy8787's Avatar
    I am also considering jumping to the pixel 3a or even the regular pixel if I trade in my phone I wouldn't need to do a down payment my s9+ since pie hasn't been working right and the battery drains to fast it's dead by 3pm.
    05-13-2019 07:53 PM
  3. mustang7757's Avatar
    It's your choice and what you want in the end and if that makes you happy go for it, me personally I wouldn't.
    05-13-2019 10:28 PM
  4. MrsNorris428's Avatar
    Yeah, I've decided to get the 3a XL. I'm going to give my mom my S9+ and trade in her S8+. She thinks I'm crazy every time I switch phones but I told her unless Google also makes a purple-ish pixel 4 I'll stick with the 3a...for now.
    05-14-2019 12:30 AM
  5. Golurk's Avatar
    Is colour really that bad? The Samsung equivalent on the S9+ to purple-is is lavender...only very minor difference between the two.
    But yeah, the only thing you’ll be gaining with the 3a XL compared to the S9+ is purer, longer software updates and battery life.
    Cameras should be about the same hopefully, but the negatives are no expandable storage, IP rating, inferior design, no face/iris scan, plastic build and inferior performance.
    Personally I’d keep the S9+, but if you’re happy with your new 3a XL then good for you!
    05-14-2019 12:53 PM
  6. Mike Dee's Avatar
    The phone you should be comparing to the S9+ is the Pixel 3XL. I'm guessing you didn't buy the S9+ for the specs
    05-14-2019 01:37 PM
  7. MrsNorris428's Avatar
    I didn't, but I did decide to get the 3a XL instead of the 3a.
    missy8787 likes this.
    05-14-2019 01:41 PM
  8. Golurk's Avatar
    How are you finding the phone? Is it too big to use easily?
    05-16-2019 12:49 PM
  1. S9 won't transfer any files
    By DJ_Explosive in forum Samsung Galaxy S9 & S9+
    Last Post: 05-15-2019, 08:50 AM
