1. gray2018's Avatar
    Recently "upgraded" to the S9 plus on T-Mobile from the LG V30. I'm having horrible battery life. I'm currently on Pie if that makes a difference, which it came loaded with. I didn't update to it. I'm really bummed about this because the battery on my V30 literally lasts me all day and still have 15-30% when I wake up at 5AM and go to bed at 1030 at night. I find myself having to charge the S9 twice a day even on power saving mode, medium resolution and lowered brightness. If I have to do all that, I might as well just keep my V30 as I don't have to do that with it. There are battery cases like the Zerolemon, but I'd rather not go that route as the S9 Plus is already huge and awkward enough.
    Anybody have any suggestions? Because it's bad enough to the point where I'm considering just returning it.
    05-16-2019 04:35 PM
  2. pontiac005's Avatar
    Factory reset usually fixes that. Also it can be a rogue app. I get great battery life on my S9+
    lucianus_luciferus likes this.
    05-18-2019 12:58 AM
  3. Golurk's Avatar
    Use the in built Device Maintenance app to clear up junk files and essentially refresh your phone from time to time...it should also pick up any apps that crash or use too much battery and alert you to the problem. Hidden ads could also be a problem.
    Reviews say the S9+’s battery life is nothing special but solid (all day), so it’s probably not an issue with Samsung itself
    pontiac005 likes this.
    08-02-2019 12:22 PM
  4. Andrew_404's Avatar
    I have the standard S9 and had really poor battery life too. I was about to return the phone to Best Buy and decided to do a NEW, factory clean reset. Did not copy any files or backups from my old phone. The battery life has seriously double on SOT time. I can go easily 16 hours with heavy usage and 1.5 days light. So, the plus should be doing way better I would assume..
    08-08-2019 08:06 AM
  1. Audio on G8
    By gray2018 in forum LG G8 ThinQ
    Last Post: 05-18-2019, 09:56 AM
  2. Galaxy S7 home wallpaper keeps changing on its own
    By DisturbedShifty in forum General Help and How To
    Last Post: 05-16-2019, 04:18 PM
  3. Can I recover the deleted "ETC" file on my tablet..?! O_o
    By Mountain Dwells in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 09-27-2017, 06:04 PM
  4. Replies: 9
    Last Post: 05-18-2016, 04:13 PM
  5. Galaxy S5 Battery Life
    By codyoehl in forum Samsung Galaxy S5
    Last Post: 09-27-2014, 09:28 PM
