1. ivanwi11iams's Avatar
    For the past month or so, I had my S9+ in a drawer, while I was using my iPhone XS Max.
    The other day, I took it out, charged it, and started to use it.
    After a few days, I am still struggling to get used to Android Pie again.
    Weird really.
    Merely sharing. I probably won't notice the use of it, after a week or so...
    05-22-2019 07:17 PM
  2. mustang7757's Avatar
    Weird really.
    What problem your experiencing on Pie?
    05-22-2019 10:43 PM
  3. ivanwi11iams's Avatar
    No problem, per se. Merely trying to get reacquainted with Android
    05-23-2019 07:02 PM
  4. mustang7757's Avatar
    That's fine , lot of things you can do , dont hesitate and ask .
    05-23-2019 07:11 PM
  1. Pixel 3 still makes notifications sounds in vibration
    By Android Central Question in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 06-05-2019, 03:37 PM
  2. Trading in my Note 9 for the Oneplus 7 Pro
    By bshend in forum OnePlus 7 & OnePlus 7 Pro
    Last Post: 05-24-2019, 07:01 AM
  3. Any smartphone suggestion that doesn't look like a brick in the hand?
    Last Post: 05-22-2019, 07:21 PM
  4. Pixel 3 still makes notifications sounds in vibration
    Last Post: 05-22-2019, 01:22 PM
  5. Google not helping in search
    Last Post: 05-22-2019, 11:01 AM
