1. Mr Big Stack's Avatar
    For at least a week my notification alert sounds off at least a dozen times a day! I check the phone and there is no email or text message.
    I've had McAfee Security installed since I bought the phone. Ran a deep scan twice. I checked battery and data usage, nothing out of the ordinary.
    Driving me crazy, any ideas? The phone is about a year old.
    Samsung Galaxy S9 Plus, Model: SM-G965U, Android 9, One UI V 1.0
    05-31-2019 05:18 PM
  2. Rukbat's Avatar
    Check all your apps - one of them might have notifications enabled and either you forgot that you enabled them, or you didn't know that they were enabled when you installed it.
    05-31-2019 06:04 PM
  1. Can't migrate data to SD card with Moto G5
    Last Post: 06-02-2019, 01:20 PM
  2. Moto G7 Power - Tap to Wake
    By Android Central Question in forum Moto G7 Power
    Last Post: 06-02-2019, 10:36 AM
  3. Replies: 2
    Last Post: 05-31-2019, 05:35 PM
  4. How do I delete Windows when the phone says window limit reached if you don't
    Last Post: 05-31-2019, 05:12 PM
  5. how can i use my smartwarch without a sims card
    Last Post: 05-31-2019, 04:49 PM
