Yesterday 09:19 AM
36 12
tools
  1. distylynn's Avatar
    This keeps on popping up mostly in my Messaging app ,mostly.I have done everything from turning on all app permissions to turning them all off . I've called the Samsung help several times, please, what can I do? Nothing seems to make it stop! It started about a month 2. It didn't used to be. So frustrating. Oh yeah a samsung galaxy s9+. I just uninstalled and reinstalled the messenger app and it didn't help. suggestions? How exactly to reply o know I did it once but idk how? The the Facebook messenger app but it also does it in general.
    06-18-2019 12:30 AM
  2. Javier P's Avatar
    Back on July 3rd. U said screenshots would help. So I've taken some. I just dont know how to get them on here in my question or reply. And exactly how do I tag u? Thank u by the way for your trying to help me with this problem.
    As @mustang7757 said the right steps to post screenshots will depend on which app you are using to access the forums (browser, AC, ACF, Tapatalk ...). See this guide.
    https://forums.androidcentral.com/sh...d.php?t=737130
    To tag any member type @username, as I did in this post.
  3. pontiac005's Avatar
    Have you uninstalled and reinstalled the messaging app?
    06-18-2019 08:32 PM
  4. distylynn's Avatar
    No that did not work. More suggestions?
    06-19-2019 03:40 PM
  5. krisqz's Avatar
    What messenger app? Stock SMS app or Facebook Messenger?
    06-20-2019 05:35 AM
  6. distylynn's Avatar
    Ok I think I see how to reply now go to original question save and then the reply will pop up. So yeah the no permission to show top window pops up almost everywhere.
    06-20-2019 12:38 PM
  7. krisqz's Avatar
    Again, which app are you talking about?
    06-20-2019 02:15 PM
  8. distylynn's Avatar
    I think it started out in the messenger app that would be the one downloaded from play store. But now it shows up all the time. On most screens .
    06-27-2019 06:15 PM
  9. distylynn's Avatar
    Can anyone help me this is most annoying.
    07-02-2019 08:48 PM
  10. mustang7757's Avatar
    Like a chat bubble ?
    07-02-2019 08:52 PM
  11. mustang7757's Avatar
    Try resetting app preference in settings,3 Dots upper right corner ,tap app preference and choose reset
    07-02-2019 08:58 PM
  12. distylynn's Avatar
    I did that before, but I just tried it again. It had no effect on when it pops up? What is a chat bubble good for, and how do I get one?
    07-02-2019 11:32 PM
  13. mustang7757's Avatar
    You know how in messenger a floating icon will appear when message comes in and tap to expand it
    07-02-2019 11:42 PM
  14. mustang7757's Avatar
    This is in Facebook messenger
    You can get there by long press the icon >tap info>notification and adjust or turn offNo permission to show top window-screenshot_20190703-010217_settings.jpeg
    07-03-2019 12:04 AM
  15. distylynn's Avatar
    Any more suggestions in how to get rid off this no permission to show top window? I think I've tried just about everything.
    07-03-2019 10:52 AM
  16. mustang7757's Avatar
    Sure I have more things to check.
    In settings >type in search bar appear on top tap it and see any apps you want to disable there.
    07-03-2019 10:55 AM
  17. mustang7757's Avatar
    Can also type pin window make sure that's offNo permission to show top window-screenshot_20190703-115917_settings.jpeg
    07-03-2019 10:59 AM
  18. mustang7757's Avatar
    Also if you could provide some screenshots of the issue , be very helpful.
    07-03-2019 11:05 AM
  19. distylynn's Avatar
    What do u mean, top tap it?
    07-04-2019 08:37 PM
  20. mustang7757's Avatar
    When you type appear on top it will give option underneath tap on it when it shows up
    07-04-2019 09:01 PM
  21. distylynn's Avatar
    How do I share screenshots to here?
    07-05-2019 02:26 AM
  22. distylynn's Avatar
    U went to settings and in the search bar I typed appear on top, there were no results. I've taken several screen shots of the problem. Now I just need to know how to get them to u.
    07-05-2019 05:32 AM
  23. mustang7757's Avatar
    How do you access the forums? The app or forum app?
    07-05-2019 07:55 AM
  24. distylynn's Avatar
    I went to forums in the menu, and I think this is a forum because there were a bunch of questions one of them was mine and when I started it. So how do I share screenshots to here?
    07-05-2019 08:21 AM
  25. distylynn's Avatar
    I just did the pin window search and it was on. I turned it off and it didnt change a rging.
    07-05-2019 08:24 AM
  26. johniii's Avatar
    did you restart phone after the pin window being turned off?
    07-07-2019 11:23 PM
36 12
  1. Replies: 2
    Last Post: 06-18-2019, 09:49 PM
  2. Is there a way to swap functions of left/right button of a bluetooth mouse?
    Last Post: 06-18-2019, 02:17 AM
  3. How to reverse mouse click settings on Android tablet
    Last Post: 06-17-2019, 07:47 PM
  4. Show all comments in Facebook app
    By Zoostation in forum Samsung Galaxy S9 & S9+
    Last Post: 06-17-2019, 05:40 PM
  5. Show all comments in Facebook app
    By Zoostation in forum Ask a Question
