fake samsung s9+
anon(10613606)
I have a problem I'd like to ask you a question for.
As I know now, and you probably also know, the real S9+ has a sled, which allows you to insert a SIM card and a memory card at the same time.
With my fake smartphone, which I bought without much thought at a flea market, I can see the opening but I don't have that sled at my disposal.
My question is if you could tell me more about the manufacturer by means of 2 attached pictures of the back of my phone in this mail.
This might help me to get some information there.
I hope that this is not too much to ask of you and thank you very much for all your help.
With polite greetings !!
Rukbat
Retired Moderator
Feb 12, 2012
44,529
27
A picture of where the SIM goes might be more helpful. If there's just an empty slot there, you're just missing the SIM tray. You can buy them ob eBay for about $2-$3.
anon(10613606)
Dear Sir,
As requested by you, I hereby enclose a picture of the empty lock.
On the picture the lock is on the far right.
If I have measured correctly it has a width of 7 mm.
Do you think that an original sled (for sale on ebay as you said) could fit in the lock of my fake smartphone?
mlblack16
1,101
465
83
The Sim card slot/tray is on the other end of the phone. You can use a paper clip to gently push into the release and the tray should pop out slightly for you to pull the rest of the way out.
chanchan05
Q&A Team
Nov 22, 2014
8,519
I mean the port to the right. The one in the center is a charging port
Yes, but there looks like a mesh inside it. I have experience with these fakes, and the ones I've seen all put the sim slot on the top or the side.
The Samsung "sled" is also way bigger because it includes a pinhole for the tool. It's about 2x as wide as that speaker grill shown in the picture. Partly because the SIM is put lengthwise on the sled.
Mike Dee
Ambassador
May 14, 2014
23,368
192
63
Well the OP thinks it a slot and it's a fake and an unclear photo so who knows at this point and the OP hasn't responded after posting the photo.
mlblack16
1,101
465
83
The OP posted a pic of the bottom of the phone. Even if the phone has a sim tray, that doesn't guarantee it's real anyways. I've seen videos on YouTube how the knock offs are getting amazingly similar to the original, down to minute details.
Mike Dee
Ambassador
May 14, 2014
23,368
192
63
The OP knows it's not real
emii
