Do Not Disturb does NOT work
Abbers727
371
16
One thing you can be happy about , you now know how to flash the firmware through Odin .
Question - I may have to do a factory reset again, will that mess up what I just did when I flashed the firmware?
I have this app, Package disabler Pro that I activated but now it's causing me problems and I can't get to the part of the app to uninstall it and it's pretty much the only way to uninstall the app besides doing a factory reset to uninstall it before I activate it .
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,184
5,857
113
No factory reset won't affect the firmware , but and big but , you have package disabler on your phone? This whole time?
Abbers727
371
16
I've had Package disabler Pro on my phone for a while and it was working and not giving me issues, I don't think. And then I didn't open the app up when I did the Factory reset earlier this week.It was only after I did the flash the firmware that I tried to open the app up and activate the app.
Do you think that maybe the Package disabler Pro may... and it's probably a big MAYBE causing the issue with the Dnd?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,184
5,857
113
It's a very good possibility
You have to take it out of administrative App before uninstall and put anything you changed back the way it was.
Abbers727
371
16
Lol.. I hope we got it this time
Well, I asked my friend to send me a message back on Messenger and I didn't hear it. I still heard the 'popping' sound that Twitter makes when you try to check for new tweets. I'm waiting to see if I hear e-mail notifications.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,184
5,857
113
Ok let's see on the others
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,184
5,857
113
You can't get rid of it from apps list?
This is stock email when I long press it and tap info>then tap notification
Stock e-mail
I decided to clear the cache partition and the Package Disabler Pro+ app appeared on my apps page. So I removed it again and removed it from my google play library.
MickTavia
