Yeah , I Know it's fustrating to want something to work as simple as that and don'tI know! I thought well, maybe it worked. Yea, I'll try to play with the settings in DND. I just don't know what's wrong with it.
One thing you can be happy about , you now know how to flash the firmware through Odin .
No factory reset won't affect the firmware , but and big but , you have package disabler on your phone? This whole time?Question - I may have to do a factory reset again, will that mess up what I just did when I flashed the firmware?
I have this app, Package disabler Pro that I activated but now it's causing me problems and I can't get to the part of the app to uninstall it and it's pretty much the only way to uninstall the app besides doing a factory reset to uninstall it before I activate it .
It's a very good possibilityI've had Package disabler Pro on my phone for a while and it was working and not giving me issues, I don't think. And then I didn't open the app up when I did the Factory reset earlier this week.It was only after I did the flash the firmware that I tried to open the app up and activate the app.
Do you think that maybe the Package disabler Pro may... and it's probably a big MAYBE causing the issue with the Dnd?
You have to take it out of administrative App before uninstall and put anything you changed back the way it was.
I just started factory reset and I unchecked the box to put it back on my phone.
Ok perfect , let's see this time around
Fingers crossed! I was like if I could keep it from even being installed or placed on my phone before it finishes putting my stuff back on my phone, I was going to do it. lol
Lol.. I hope we got it this time
Ok let's see on the othersWell, I asked my friend to send me a message back on Messenger and I didn't hear it. I still heard the 'popping' sound that Twitter makes when you try to check for new tweets. I'm waiting to see if I hear e-mail notifications.
Which email you use ?Unfortunately, I still heard the e-mail notification sound. :/
You can't get rid of it from apps list?
This is stock email when I long press it and tap info>then tap notification View attachment 304861
Make sure ignore DND isn't enabled
Oh wow, finally got to the bottom of itMaybe that's been one of the issues all along! That those options were enabled!! I just disabled them after seeing your posts.
