Originally Posted by
Abbers727 Sure. If it'll help with this issue!
Ok I will leave these steps
1. Download Odin 3.13
2. Download correct files for your model number and when you download the files to your computer you'll need to extract the files , after it will be 4 files you'll need.
Open Odin
4 slots you'll need to put the corresponding files
Bl in BL
Ap in AP
Cp in CP
CSC in CSC
THEN HIT START
but make sure you power your device off hook up to the computer before device starts you hold volume down,bixby,power button same time until download mode shows and it will prompt hit volume up then hit start
