Can sense the frustration, but you need to go to the Settings, notifications and explore till you find the apps you want notification from and confirm the priority of the app is the highest. There are a myriad of reasons in addition, but start with this.
And, after your update, clear the cache partition and reboot.
Also, if it is activating dnd in your car, you may have a Routine set up with Goodlock or such, activating when it connects to your Bluetooth. More info will be needed.
Good luck
06-28-2019 05:32 AM
