1. pauljjr's Avatar
    My S9 Battery was at 5% and I put it on my wireless charger for the night.
    It must not have been positioned correctly and the battery went to "0" % and the phone shut off.
    When I awakened, I realized what happened and I am now charging the phone with my fast charging wire. It is already up to 35%/
    SO......did I hurt my battery by allowing it to go to "0" % ????
    Let me know what to expect in the future.
    Thanks.
    08-24-2019 04:15 AM
  2. Mooncatt's Avatar
    Li-ion batteries are not deep cycle batteries. Draining to zero will cause excessive wear, but so will draining to 5%. If you're doing this regularly, then I'm sure your battery has already suffered a capacity loss.
    08-24-2019 07:37 AM
  3. pauljjr's Avatar
    Normally I recharge between 20 - 50%.
    This is the first time I have experienced "0"% charge.
    Its charged full now and seems to be OK.
    I also have found out that a method to re-calibrate the S9 battery is to allow it to go to "0"% twice and restart.
    I'll keep a "eye" on my battery and reply later if I see anything different in its use.
    Thanks.
    08-24-2019 08:07 AM
  4. mustang7757's Avatar
    I think your going be ok
    pontiac005 likes this.
    08-24-2019 08:41 AM
  5. pauljjr's Avatar
    So far the battery has been working as expected.
    I cycle it pretty deep so I exercise the battery capacity well.
    Don't see any memory effect or decrease in functionality due to the complete discharge.
    Thanks for all of the input.
    09-01-2019 04:51 AM
  6. mustang7757's Avatar
    Glad to hear that
    Thanks for letting us know.
    09-01-2019 10:21 AM
  7. pontiac005's Avatar
    I wouldn't worry about it. You would have to do that alot for it to start degrading the battery. I have done that quite a bit on my S7 plus and it lasted me three years before I started having battery problems. By then I was ready to upgrade anyways since I stopped receiving the security patches.
    mustang7757 likes this.
    09-01-2019 12:11 PM
  1. DeX - moving files from the phone to the Mac
    By zipro in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 05-20-2020, 04:45 PM
  2. Note 10 Wallpapers to Hide Camera Hole
    By smooth4lyfe in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-06-2019, 09:38 AM
  3. Phone rings but no controls on the screen to answer it
    Last Post: 08-24-2019, 01:40 PM
  4. Is there any way to remove speed dial feature?
    Last Post: 08-24-2019, 12:48 PM
  5. how to change ring tones for each inividual contact?
    Last Post: 08-24-2019, 06:48 AM
