B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,167 4,263 113 Visit site Aug 25, 2019 #2 Welcome to Android Central! Are you using the laptop's USB-A port, or is it a USB-C port? Have you tried different cables? Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
mustang7757 Super Moderator Moderator Feb 6, 2017 91,060 5,740 113 Visit site Aug 25, 2019 #3 See if the charger port needs cleaning?
K krisqz Well-known member May 7, 2013 287 24 18 Visit site Aug 26, 2019 #4 Did you select proper option on the phone?
mustang7757 Super Moderator Moderator Feb 6, 2017 91,060 5,740 113 Visit site Aug 26, 2019 #5 krisqz said: Did you select proper option on the phone? Click to expand... Hi, Welcome! Should be in notification panel to change the settings
Casey Cheung Well-known member Mar 7, 2011 1,234 5 0 Visit site Aug 26, 2019 #6 Charging is the easy part. Transferring files takes more effort.
rjack22 Well-known member Jan 25, 2011 796 51 28 Visit site Aug 27, 2019 #7 Is it the OEM charging cable that you are using? Not all cables are created equal. Some cannot be used for data transfer for example. Try a different cable.
