My phone is not charging at all and it shows the moisture detector sigh
My phone is a Samsung s9 and it’s more thn 2years old don’t know if I should change the battery or do something else
Re: My phone is not charging at all and it shows the moisture detector sigh
Hi, welcome to Android Forums
I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
I'll provide a link to register, please come back to your post so we can further assist you . Thank you
https://forums.androidcentral.com/sh...d.php?t=409154
Try use a fan or hair dryer on medium cool for about 5 to 10 minutes ...then retry
You can always charge wirelessly
What's worked for some is go into the app manager, clear the USB app data, then restart the phone.
Originally Posted by
Android Central Question My phone is a Samsung s9 and it’s more thn 2years old don’t know if I should change the battery or do something else
I'm having the same exact issue. Getting frustrated. I actually had to change my sim card to the old pixel 2xl till I get issue resolved.
I was having the same issue with my note 9. I took it to a service center and they cleaned the USB C port and I haven't had any issues since then.
Have you tried more than one charger. I have 1 or 2 chargers that I get the same notice from. As long as I don't use them I'm fine.
