    My phone is a Samsung s9 and it’s more thn 2years old don’t know if I should change the battery or do something else
    08-28-2019 04:51 PM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist you . Thank you
    https://forums.androidcentral.com/sh...d.php?t=409154
    08-28-2019 05:50 PM
  3. mustang7757's Avatar
    Try use a fan or hair dryer on medium cool for about 5 to 10 minutes ...then retry
    08-28-2019 05:51 PM
  4. blackops1125's Avatar
    You can always charge wirelessly
    08-28-2019 07:54 PM
  5. Mooncatt's Avatar
    What's worked for some is go into the app manager, clear the USB app data, then restart the phone.
    08-28-2019 08:29 PM
  6. aztec12's Avatar
    I'm having the same exact issue. Getting frustrated. I actually had to change my sim card to the old pixel 2xl till I get issue resolved.
    08-29-2019 09:37 PM
  7. amellerbe's Avatar
    I was having the same issue with my note 9. I took it to a service center and they cleaned the USB C port and I haven't had any issues since then.
    pontiac005 likes this.
    09-06-2019 04:12 PM
  8. ggrr8t's Avatar
    Have you tried more than one charger. I have 1 or 2 chargers that I get the same notice from. As long as I don't use them I'm fine.
    10-09-2019 12:12 PM
  1. Why can't I fix my damn battery drain problem
    Last Post: 08-29-2019, 12:18 PM
  2. facebook is not connecting to wifi
    Last Post: 08-28-2019, 10:37 PM
  3. Is there an aftermarket metal/magnetic band for Samsung Galaxy Fit?
    Last Post: 08-28-2019, 10:34 PM
  4. Samsung Watch email is a month old and doesn't update
    By Android Central Question in forum Samsung Galaxy Watch
    Last Post: 08-28-2019, 10:31 PM
  5. Volume control after Android update does not work properly
    Last Post: 08-28-2019, 10:30 PM
