1. Gandhi113's Avatar
    ...so that it will prompt me for the new password. Anyone? Thanks..
    08-29-2019 08:31 AM
  2. SpookDroid's Avatar
    From the Wi-Fi Settings area (you can access that by long-pressing the WiFi toggle in your notification bar), you have a couple of options. You can just delete the WiFi connection (long press, 'Forget network') and when you re-add it it should ask for credentials again. Or, you can use the same connection and just long-press it, this time select 'Manage network settings' and edit the Security section with the updated credentials.
    08-29-2019 08:40 AM
  3. Gandhi113's Avatar
    Thanks!
    08-29-2019 11:21 AM
  4. SpookDroid's Avatar
    08-29-2019 11:31 AM
  1. Why does my HTC U11+ randomly reboot?
    By Ron MacRae in forum HTC U11
    Last Post: 10-29-2019, 07:42 AM
  2. Where is the Christian cross that was on the phone icon, why did you remove this?
    Last Post: 08-29-2019, 12:29 PM
  3. why am I not able to send text messages on my one plus 5T ?
    Last Post: 08-29-2019, 12:24 PM
  4. Replies: 1
    Last Post: 08-29-2019, 11:32 AM
  5. Unique (at least to me) Way to Register Your Finger Prints for More Accuracy
    By rabernet in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-29-2019, 07:37 AM
