1. blueskyhigh's Avatar
    When I connected it, the TV monitor states "make sure that all four corners of the screen fit your monitor or tv........." However, the "OK" control button only shows up on the TV screen and I'm unable to control it on the phone or with the TV control. I can't move forward. I was able to connect it before directly, without this screen showing up on the TV.
    09-01-2019 11:55 AM
  2. mustang7757's Avatar
    09-01-2019 07:10 PM
  3. mustang7757's Avatar
    I'm going leave a link from your original post to avoid duplicates.
    https://forums.androidcentral.com/sh...d.php?t=975543
    09-01-2019 07:22 PM
  4. SpookDroid's Avatar
    Have you tried connecting a BT mouse or keyboard? What about the back button?
    09-01-2019 07:28 PM
  5. Rukbat's Avatar
    [Merged and cleaned]
    09-02-2019 12:07 PM
  6. SpookDroid's Avatar
    Also sounds like you're booting up DeX for the first time, so check your connection settings on the phone (notification bar) if that's not the mode you're trying to use.
    09-02-2019 06:27 PM
  1. Photo aspect ratio/resolution? Confused as what setting to use
    By Borgie in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-23-2019, 08:15 PM
  2. How to get my galaxy j4 back onto auto reconnect for my wifi
    Last Post: 09-02-2019, 10:03 PM
  3. An air combat game with an ecchi 3d female pilot.
    Last Post: 09-02-2019, 08:40 AM
