1. Andy Tee's Avatar
    S9. If I uninstall an ap from the home screen after long-tapping the icon, I cannot re-install the same ap from the play store. After tapping 'Install' I get the 'Waiting for download' message even on wifi.
    This only happhappens if the uninstall was from the homescreen. If I uninstall from Settings > Aps it's all good.
    09-05-2019 05:24 PM
  2. mustang7757's Avatar
    That's strange , have you tried any steps to correct this?
    09-05-2019 05:26 PM
  3. Andy Tee's Avatar
    'Steps to correct this' is what I'm hoping for!!
    Specific aops affected are Spotify and Snapseed.
    09-05-2019 05:37 PM
  4. mustang7757's Avatar
    Ok ...go in phone settings and type in search bar reset ,then go into reset settings and see if this helps
    Andy Tee likes this.
    09-05-2019 05:38 PM
  5. Andy Tee's Avatar
    Reset and problem solved.
    Thanks
    mustang7757 likes this.
    09-05-2019 06:54 PM
  6. mustang7757's Avatar
    Thanks
    Your welcome!
    Hope to see you around the forums!
    09-05-2019 07:34 PM
  1. Why are some upcoming phones not listed?
    By unclefunbuckets in forum Rumored Devices Lounge
    Last Post: 10-03-2019, 06:18 PM
  2. How to transfer daa from Samsung note 4 to Samsung not 8?
    Last Post: 09-05-2019, 08:36 PM
  3. why my lg h442 mobiles is not start?
    Last Post: 09-05-2019, 12:53 PM
  4. Play Store Not Updating Apps Even Though Auto-Update Enabled
    By PsychDoc in forum Samsung Galaxy S10 & S10+
    Last Post: 09-05-2019, 12:21 PM
  5. Why are all my photos not showing up on photos.google.com
    Last Post: 09-05-2019, 10:44 AM
