1. preyn1351's Avatar
    I recently purchased a Flinevetech A8 bluetooth headset. I am able to connect the device via bluetooth but it will only connect for audio but not for phone calls. I went into settings to change the device to accept phone calls but the button to select calls will not stay enabled and reverts back to off.
    09-26-2019 06:24 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you have other Bluetooth devices nearby that might be competing for the connection?
    09-27-2019 12:20 PM
  3. Rukbat's Avatar
    The headset might not be "saying" that it has phone call ability properly, so the phone thinks it's an earphone and won't use it for calls. Contact Flinevetech at support@flinevetech.com.
    09-27-2019 01:46 PM
  4. keifferr's Avatar
    Since adjusting the Bluetooth settings didn't help, I would contact the manufacturer directly.
    10-07-2019 03:52 AM
  1. My notification bar will not scroll down
    Last Post: 09-27-2019, 01:40 PM
  2. Replies: 2
    Last Post: 09-27-2019, 01:35 PM
  3. How do I get access to the sound notification when calls are received?
    Last Post: 09-26-2019, 01:50 PM
  4. Replies: 1
    Last Post: 09-26-2019, 12:54 PM
