I've just noticed the play store has a dark mode during night time. No idea how or when it updated. Pretty cool
I have the S9+ from Verizon. I am using a theme from the Galaxy Themes store. The Google Play store on my phone still shows the bright white and yes...I have the latest version of the Google Play store on my phone. So do I need to use default theme to get the dark mode for the Google Play store and also for the Google assistant?
No shouldn't interfere.Will this not work if I'm using nova launcher?
Yes, you have to be on the system dark mode to have Play Store be dark also.
Yes it looks like you have to be on the default theme.
You can check this if you open the galaxy themes app and tap on the themes button at the bottom of the screen.
Now you won't see your downloaded themes unless you swipe down on the screen to reveal them. Then tap on the View all and that will show you all the themes.
And make sure the default one is set.
