1. jagadeeshdv's Avatar
    When i switch the display on/off within few seconds the display turns dim and horizontal lines allover the screen. it happens even during call when i bring my phone close to ear and bring down immediately. basically a fast switching between on and off screen. it recovers if i off the screen for a while and on back.
    11-15-2019 06:52 PM
  2. mustang7757's Avatar
    Hi, welcome!
    Sounds like your digitalizar (screen ) needs repair, can you get a screenshot of it?
    11-15-2019 08:07 PM
  3. jagadeeshdv's Avatar
    i'm sending the two different picture to compare.
    S9 Plus Display issue-img-20191115-wa0006.jpgS9 Plus Display issue-img-20191115-wa0007.jpg
    11-15-2019 08:41 PM
  4. mustang7757's Avatar
    if i take screen shot no difference can be seen after it screen turns to normal. i'm sending the two different picture taken using my camera.Click image for larger version.
ID:	313146Click image for larger version.
    Thanks for sharing, do you have any warranty ? Something wrong with that display
    11-15-2019 08:43 PM
  5. jagadeeshdv's Avatar
    nope. just expired two months ago. bad luck.
    11-15-2019 08:50 PM
  6. mustang7757's Avatar
    Oh wow
    11-15-2019 09:24 PM
  7. pontiac005's Avatar
    Looks like it went bad on you.
    11-15-2019 11:33 PM
  8. jagadeeshdv's Avatar
    yes, but the good thing is, if i turn off the screen and on back after 10 or 15sec later the screen seems to be normal. it happens only if there is quick switch over like when the display is ON then if i OFF then ON back immediately or during call if the screen OFF n ON due to proximity sensor behavior. very strange.
    11-16-2019 12:32 AM
  9. pizza_pablo's Avatar
    It may help to try different animation settings in developer options.
    11-16-2019 11:29 AM
  10. jagadeeshdv's Avatar
    yes, tried but didn't help. Also did a soft reset and even the safe mode. None helped. Tks
    11-16-2019 07:10 PM
  11. mustang7757's Avatar
    Yeah this a screen issue .
    11-16-2019 09:37 PM
  1. AT&T Note 10+ replaced with Unlocked Note 10+. Now I am having connection issues. Any ideas?
    By Jonnny4 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 12-06-2019, 07:04 PM
  2. S10 - issues with photos saved to Micro SD card
    Last Post: 11-16-2019, 05:32 PM
  3. Why can't Nokia 7 Plus return to the previous place
    By Android Central Question in forum Nokia 7 Plus
    Last Post: 11-16-2019, 05:25 PM
  4. Why wont Disney plus let me log in onto my lg smart tv?
    Last Post: 11-15-2019, 11:44 PM
  5. Why can't Nokia 7 Plus return to the previous place
    Last Post: 11-15-2019, 11:52 AM
