1. GatsbyGlen's Avatar
    I saw another thread about this for the S7, but my S9+ has recently started to do this at around 40%, it goes to zero and phone shuts off. Phone will be 2 years old in Spring. First Samsung phone, long time user of Motorola before that, and I never had that sort of battery issue with Motorola. Guess I need to buy a new battery? I also had an LG phone once before too, but that suffered the boot loop issue.
    11-25-2019 09:05 AM
  2. mustang7757's Avatar
    Yeah sounds like the battery
    11-25-2019 09:31 AM
  3. B. Diddy's Avatar
    Do you frequently let the battery drop to zero or near-zero? If so, 2 years is probably the right time for it to start exhibiting behavior like this, since frequent deep discharges can shorten the battery's lifespan.
    11-25-2019 01:42 PM
  4. pizza_pablo's Avatar
    11-25-2019 10:24 PM
  5. pontiac005's Avatar
    A friend did this and he said it was real easy.
    11-28-2019 11:26 AM
  6. Mooncatt's Avatar
    Textbook symptom of a worn out battery.
    As for the LG comment, their G4 and V10 phones had a design flaw causing bootloops, and are not related to the problem with the S7.
    11-28-2019 11:56 AM
  1. bored with samsung, need advice on what to do?
    By delta7 in forum Ask a Question
    Last Post: 11-25-2019, 07:49 PM
  2. How do i recover a number I typed on my keypad but forgot to save?
    Last Post: 11-25-2019, 04:45 PM
  3. How to use Android App on Mac?
    By KurtPattinson in forum General Help and How To
    Last Post: 11-25-2019, 02:48 PM
  4. Android phone connects to Windows but Windows can not see any files
    Last Post: 11-25-2019, 02:28 PM
  5. Samsung j7 aura downgrade to 8
    Last Post: 11-25-2019, 02:07 PM
