    I have set up ring doorbell 2 on my iphone 7, my wifes iphone, my brothers iphone and my dads s9 all with no issues and they all receive notifications when the doorbell is rung.
    However my mothers s9+ which is running the same software as my fathers (9 pie) does not give any notifications for nothing Ring doorbell related - not even motion. Called Ring and they couldn't help either.
    I have tried absolutely everything from resetting the phone settings, to deleting the app and installing again and also giving it permissions to absolutely everything.
    Please some one help!!
    01-06-2020 02:52 PM
  2. tlc264's Avatar
    Try the new app rapid ring. It is from Ring and it is supposed to help out.
    01-06-2020 03:13 PM
  3. adzysf's Avatar
    I have tried using rapid ring too still no notifications
    01-06-2020 03:17 PM
  4. mustang7757's Avatar
    Long press the ring app tap info and scroll to notification see if everything checked there.
    01-06-2020 03:38 PM
  5. adzysf's Avatar
    No joy trying this as well everything is enabled - maybe it is just the ring app version and i will have to wait for an update?
    01-06-2020 04:16 PM
  6. mustang7757's Avatar
    Possible, or give them a email
    01-06-2020 04:36 PM
  7. pizza_pablo's Avatar
    I'm sure you have, but just in case...
    Besides in the app itself, have you selected the Ring app to receive notifications in the phones main SETTINGS , NOTIFICATIONS , SELECT WHICH APPS YOU WANT TO RECEIVE NOTIFICATIONS FROM ? Why does my s9+ not show me Ring Doorbell 2 notifications?-20200106_180802.jpeg
    01-06-2020 08:08 PM
  8. adzysf's Avatar
    yes all notifications for ring have been switched on and still no joy - i honestly do not know what it could be
    01-07-2020 02:40 PM
  9. mustang7757's Avatar
    I would contact them see what they say
    01-07-2020 02:45 PM
  10. adzysf's Avatar
    i called them yesterday and they didnt seem to know what the issue was as well lol i literally have tried all avenues!
    01-07-2020 02:51 PM
  11. mustang7757's Avatar
    Check in device care if that app has been put to sleep ?
    01-07-2020 02:53 PM
  12. adzysf's Avatar
    just checked and the app has not been put to sleep either - its a really annoying issue i have never had before on any other devices.
    01-07-2020 03:01 PM
  13. mustang7757's Avatar
    Try something , is the device on optimize mode under battery ,put in high performance mode see if any difference?
    pizza_pablo likes this.
    01-07-2020 03:16 PM
  14. pontiac005's Avatar
    Other than seeing if the Ring app is being optimized, which should be turned off, not sure what else it could be. Both my Ring apps notifications are working fine on mine.
    mustang7757 likes this.
    01-07-2020 09:12 PM
  15. adzysf's Avatar
    are you using on a samsung galaxy s9+? optimisation settings are all correct and high. still no notifications are coming through. hmm
    01-08-2020 10:32 AM
  16. pontiac005's Avatar
    Sorry for the late response, yes I am.
    01-15-2020 11:48 AM
  17. RapidTurtle's Avatar
    I'm on a s9 Plus also, and ring works fine. Did you solve the problem?
    01-25-2020 07:15 AM
  1. T-Mobile user unable to receive my Textra messages
    Last Post: 01-09-2020, 05:00 PM
  2. snapchat account blocked on galaxy s9
    By daveye in forum Samsung Galaxy S9 & S9+
    Last Post: 01-06-2020, 03:33 PM
  3. snapchat-account blocked on Galaxy S9
    Last Post: 01-06-2020, 02:43 PM
  4. Replies: 2
    Last Post: 01-06-2020, 12:21 PM
  5. Why do S5 Contacts update to 2016 CAMRY but S10e will not
    Last Post: 01-06-2020, 11:23 AM
