1. FanGirl4Life's Avatar
    I just got my S9 less then 1 month ago from Straight Talk. For some reason, when the phone is charging, the red light won't come on. It also blinks randomly when not on the charger and has plenty of charge. All other notification lights work fine. I've restarted, deleted apps, changed notification reminder to off and toggled off the LED and back on. I wiped the cache partition also. I just updated Google and it did it again! Can someone please help?
    01-17-2020 10:58 PM
  2. Mike Dee's Avatar
    So it's charging but just doesn't indicate with the LED?
    01-18-2020 12:23 AM
  3. mustang7757's Avatar
    Check safe mode if it still happening.
    01-18-2020 02:26 AM
  4. FanGirl4Life's Avatar
    It says its charging, but very slowly, like fast charging not working.
    01-18-2020 08:46 AM
  5. FanGirl4Life's Avatar
    I cleared the cache partition in safe mode and reset app system settings. It acts up every time I update an app also.
    01-18-2020 08:48 AM
  6. Mike Dee's Avatar
    Do you have fast charging enabled in settings?
    01-18-2020 09:04 AM
  7. mustang7757's Avatar
    How did you clear cache in safe mode ?
    In safe mode it's supposed to say safe mode on bottom of the screen , did it ? Also since you got it 1 month ago you should have warranty ?
    01-18-2020 09:33 AM
  8. Mike Dee's Avatar
    Yeah....I also recommend bringing it back since from the symptoms, doesn't seem like a setting.
    01-18-2020 03:10 PM
  9. mustang7757's Avatar
    Yeah I agree , I have the s9+ and that's not normal behavior on the led notifications light .
    01-18-2020 03:12 PM
  10. pontiac005's Avatar
    Definitely swap it out. Sounds defective.
    01-18-2020 11:14 PM
  1. Why do I have no storage left on my Samsung Galaxy J5?
    By J4mesMW in forum Ask a Question
    Last Post: 01-21-2020, 04:47 PM
  2. Anyone else giving the new Edge browser a try?
    By Connert in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 01-21-2020, 12:43 PM
  3. Bluetooth headphone silences everything else when in call
    Last Post: 01-18-2020, 07:48 PM
  4. Note 10+ not playing m4a files...wft?
    Last Post: 01-18-2020, 06:16 PM
  5. Replies: 1
    Last Post: 01-17-2020, 03:53 PM
