1. bezely's Avatar
    Any recommendations on a bluetooth-enabled keyboard for my phone? It needs to be fairly portable for travel/holidays and preferably have a slot so I can stand the phone up in it while typing
    01-24-2020 04:50 PM
  2. Rukbat's Avatar
    Electronically, aside from some having a few different keys than others, they're the same, so it's a matter of which one you prefer.
    01-24-2020 05:15 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I would say that I've had issues with cheapo Bluetooth keyboards (e.g., from a company like Targus), which tended to go into some kind of sleep mode quickly. That would lead to a slight pause when I started typing again, and then often some duplicate letters as what I typed suddenly flooded onto the screen.
    Logitech is generally good at this kind of thing. I have the K480, which is a bit bulky but pretty lightweight, and it does have a slot for the phone (but it might not be big enough if you use a substantial case for your phone): http://www.logitech.com/en-us/produc...-keyboard-k480
    01-24-2020 06:05 PM
  4. bezely's Avatar
    thank you
    01-31-2020 11:59 PM
  1. Has anyone installed the Google Cam app in their phone?
    By isabel95 in forum Samsung Galaxy S10 & S10+
    Last Post: 01-30-2020, 08:11 PM
  2. Samsung wireless charger unreliable?
    By stevenfstein1 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 01-25-2020, 02:39 PM
  3. Replies: 12
    Last Post: 01-25-2020, 02:26 PM
  4. why is there a image of a man and a baby on your app that looks like me
    Last Post: 01-25-2020, 02:00 PM
  5. Replies: 6
    Last Post: 01-25-2020, 01:58 PM
