1. zeni192's Avatar
    My phone (Galaxy S9+) is connected to WiFi and only some apps work like Instagram and YouTube but other apps like Printrest, Twitter and Chrome and Discord don't work at all but they work when I use mobile Data and I really need help to fix this issue because i want to use my Wifi for other apps other than just Instagram and YouTube.
    01-27-2020 09:35 PM
  2. Laura Knotek's Avatar
    Is this your own personal WiFi network or one from an employer or other location? If it's not your own, then their firewall might be blocking those apps.
    mustang7757 likes this.
    01-27-2020 09:48 PM
  3. zeni192's Avatar
    No it's my own personal Wifi Network so how would I get these apps unblocked ?
    01-27-2020 10:06 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Log into your router's settings using your computer browser (see the router's manual to learn how) and see which security/firewall settings are turned on.
    It's also worth trying a router reboot first (by unplugging its power for about 30 seconds). If that doesn't work, see here for other ideas: http://forums.androidcentral.com/amb...-problems.html
    Mojave likes this.
    01-27-2020 10:30 PM
  5. mustang7757's Avatar
    I would try resetting network in settings under general input >reset> rest network then go to router like bill mentioned if still same
    01-27-2020 10:39 PM
  6. methodman89's Avatar
    What are your settings here?
    01-28-2020 03:39 AM
  7. zeni192's Avatar
    I tried what you guys told me to do and it worked thanks for helping me I really appreciate it
    mustang7757 and B. Diddy like this.
    01-28-2020 05:00 PM
  8. mustang7757's Avatar
    Glad to hear that
    01-28-2020 05:30 PM
  1. Why is my Android TV keep going to this screen
    By Android Central Question in forum Android TV
    Last Post: 11-29-2020, 02:55 PM
  2. Replies: 1
    Last Post: 01-28-2020, 05:50 PM
  3. How to make my alarm sound while making a phone call
    Last Post: 01-28-2020, 10:58 AM
  4. Why is my Android TV keep going to this screen
    Last Post: 01-27-2020, 06:54 PM
  5. my new TV wont let me set up
    By Twintwin in forum Ask a Question
    Last Post: 01-27-2020, 06:28 PM
