1. Cvmars24's Avatar
    Can anyone help me???
    Ever since the update on my S9 to android 10 OS, google maps cannot find GPS.
    I have read all of the support group help and comments and nothing works.
    There is no GPS option for location nor accuracy mode for high.
    I am at a loss with what to do.
    02-09-2020 11:59 AM
  2. mustang7757's Avatar
    Hi, Welcome!
    Can go settings >general manager>reset>reset settings see if that helps
    02-09-2020 12:02 PM
  3. MattTheMatt's Avatar
    I'm having the same issue, and accidentally posted in the general get help section. So far no luck from everything suggested. I'm worried it might be a factory reset for me, unless Samsung recognizes this as a widespread issue and can provide a software fix.
    mustang7757 likes this.
    02-09-2020 03:40 PM
  4. mustang7757's Avatar
    02-09-2020 03:41 PM
  1. How to disable "Data Roaming connection lost" on Samsung Galaxy S7, Android 8.0.1
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 02-09-2020, 04:30 PM
  2. How to disable "Data Roaming connection lost" on Samsung Galaxy S7, Android 8.0.1
    Last Post: 02-08-2020, 05:32 PM
  3. Lost files after Cut & Paste
    Last Post: 02-07-2020, 03:57 AM
  4. Images and videos lost after moving to sd card
    Last Post: 02-06-2020, 07:01 PM
  5. Have lost weather/battery/circular time widget from home screen
    Last Post: 02-05-2020, 06:30 AM
