1. lacasette's Avatar
    Hi
    I just replaced the battery on my Samsung Galaxy S9 phone. After the battery replacement people calling me (regular phone calls) complaints about hearing an echo of their selves. I'm able to fix this by removing the back glass cover (the one that is glued on) but as soon as I put the back glass cover back people calling me hear them selves again. So I'm not sure if I have broken anything on the back cover itself when I replaced the battery or if I have broken anything related to the speaker or mic here? If I put people on speaker there is no echo, and if I use bluetooth headset everything is working fine as well.
    I'm guessing this is hardware related so the question is which hardware component I should replace here?
    Any suggestions is greatly appreciated.
    Thanks.
    02-12-2020 04:03 AM
  2. mustang7757's Avatar
    You did the repair?
    The back glass comes off that easy?
    02-12-2020 12:43 PM
  3. lacasette's Avatar
    Yes, but I obviously need to use a heat gun every time I remove it.
    02-13-2020 07:33 AM
  4. mustang7757's Avatar
    Hi, welcome!
    If you didn't have this issue before you took it apart then something you might of damaged , might have to take to repair center.
    02-13-2020 10:03 AM
  1. How does the Samsung release affect your views and/or opinions on the Pixel 4?
    By jtcannonball in forum Google Pixel 4 & Pixel 4 XL
    Last Post: Yesterday, 09:13 PM
  2. Why is the S20 still in rumored by zFlip in Samsung
    By eshropshire in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 02-12-2020, 09:03 AM
  3. Why is my samsung keyboard responding with multiple keys?
    Last Post: 02-12-2020, 01:33 AM
  4. Samsung Upgrade Program
    Last Post: 02-12-2020, 01:32 AM
  5. Samsung Galaxy One (Concept)
    By lyingfromyou in forum Android Concepts & Dream Devices
    Last Post: 02-11-2020, 07:27 PM
