1. Charles Goldberg's Avatar
    There is no option to do this in settings/lock screen
    03-25-2020 08:32 AM
  2. anon(10614692)'s Avatar
    You can find it in display settings
    03-25-2020 09:09 AM
  3. B. Diddy's Avatar
    I think most phones don't allow you to set a timeout for the lockscreen (but I'm not sure about the S9, because I don't have one). @Galactic Zoo, can you confirm this exists on the S9, or were you thinking about the general screen timeout (which should only be for when the screen has been unlocked)?
    03-25-2020 12:46 PM
  4. anon(10614692)'s Avatar
    @B.Diddy Apologies! Was referring to screen timeout!!
    B. Diddy likes this.
    03-25-2020 01:05 PM
  5. mustang7757's Avatar
    These are only options>lock screen>secure lock settingsHow can I change my lock screen setting to timeout after 20 seconds?-screenshot_20200325-141528_settings.jpeg
    03-25-2020 01:16 PM
  6. B. Diddy's Avatar
    Right, and that setting is only for how long it takes for the phone to lock after the screen turns off.
    03-25-2020 02:27 PM
  7. mustang7757's Avatar
    I believe when you manual lock the screen power button
    And should after the normal screen time out happens
    03-25-2020 02:29 PM
  8. B. Diddy's Avatar
    But it doesn't affect how long the lockscreen stays on, which I don't think can be adjusted manually. I think some phones will shorten that duration even more if a power-saving mode is turned on.
    03-25-2020 02:32 PM
  9. mustang7757's Avatar
    If power saving mode is on it can shorten what ever it's at, for example if you choose from that screen 1 minute that means it will not lock which ask to fingerprint or password/pin until that time out met
    03-25-2020 03:01 PM
  1. My apps keep closing out for no reason
    By Lizzy_Tundra in forum Ask a Question
    Last Post: 03-26-2020, 11:58 PM
  2. Edge screen
    By Charles Goldberg in forum Samsung Galaxy S9 & S9+
    Last Post: 03-25-2020, 06:23 PM
  3. Swipe to unlock, pin required
    By rflores5432 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-25-2020, 01:33 PM
  4. Kernel settings not sticking
    By milleniumdroid in forum Ask a Question
    Last Post: 03-25-2020, 02:21 AM
  5. How can I download the mod apk game on Samsung phones?
    By randyblack in forum Ask a Question
    Last Post: 03-25-2020, 01:35 AM
