1. arktex54's Avatar
    Hello all. I don't see a sticky on what information you need so I'll post some and follow-up as needed.
    Model: SM-G965U Verizon (default time unlocked by Verizon)
    Hardware version: REV1.1
    FCC ID: A3LSMG965U
    SERIAL: RF8KC...
    Phone status: Official
    Android Version: 10
    Baseband version: G965USQU7DTA8
    Kernel version: 4.9.186
    Build number: QP1A.190711.020.G965USQU7DTA8
    Service provider SW ver: SAOMC_SM-G965U_OYN_VZW_QQ_0008_4559465250413098
    I am attempting to move from Verizon to Visible (a Verizon subsidiary). My IMEI did not check as compatible with Visible and this is what the level three rep replied with:
    Quote:
    "I did some digging and it looks like we have compatibility with*most*Galaxy S9+s. I double checked your IMEI and it is not compatible due to the carrier firmware package on that particular SKU, apologies about that!" :End Quote
    [1] What is the suggested solution to change to a carrier firmware package that will work?
    [1a] I believe you change this with Odin?
    [1b] The Samsung Unlocked version does not work with Visible.
    [2] Will it require to setup the phone again?
    [3] Will Samsung Pay / Secure Folder still work?
    UPDATE: I have data and mobile hotspot working with my S9+, but still no phone calls or texts. Keep that in mind if you need an unlimited device for data.
    Thanks
    03-26-2020 06:42 PM
  2. mustang7757's Avatar
    If visible is a Verizon subsidiary , it should work , just have to find correct APN to connect , if you mess around in Odin there's not much you could do besides flash other carrier firmware as the US version is bootloader locked .
    03-26-2020 07:21 PM
  3. arktex54's Avatar
    Calling and texting does not work, even with the correct APN settings from their ZTE phone. Data and mobile hotspot IS working. Visible IMEI checker showed it failed and when I asked why, that was the answer.
    Thanks. Is there another way to change the firmware package besides Odin? Any ideas on #2 and #3?
    03-26-2020 08:26 PM
  4. mustang7757's Avatar
    Zte phones I dont think support Verizon, which Samsung does
    03-26-2020 08:28 PM
  5. arktex54's Avatar
    The ZTE is working fine with my Verizon SIM in it. Internet, calls, and MMS.
    03-26-2020 08:33 PM
  6. mustang7757's Avatar
    I thought you just said it doesn't?
    03-26-2020 08:36 PM
  7. arktex54's Avatar
    Calling and texting does not work on Visible from the Galaxy S9+. I used the APN settings displayed on the ZTE Blade A7 (that came from Visible) and put those APN settings in my Galaxy S9+. Data and mobile hotspot works in the Galaxy S9+ on Visible.
    The Galaxy S9+ works fine with a Verizon SIM: calling, texting, MMS, internet, mobile hotspot...
    03-26-2020 08:41 PM
  8. mustang7757's Avatar
    If it doesn't work , then I'm not sure what else to say , it's not compatible. See if other members can chime in
    03-26-2020 08:49 PM
  9. arktex54's Avatar
    Is there another way to change the firmware package besides Odin? Any ideas on #2 and #3 in the original post?
    03-26-2020 08:52 PM
  10. mustang7757's Avatar
    No
    arktex54 likes this.
    03-26-2020 08:54 PM
  11. mustang7757's Avatar
    #2If you use home CSC it will not factory reset
    #3 yes because you will use stock Samsung firmware
    03-26-2020 09:02 PM
  12. arktex54's Avatar
    Is there a certain post you prefer for flashing Odin for the first time? I have Odin3 v3.14.1_3B_PatcheD and the ini file. Several posts I have visited skip a lot of details like... where do I get the flashing files?!
    I have been flashing since the Blackberry 7700 days, ROOTed plenty of Androids, and jailbroke iPhones beginning in 2009. This is just a bit different.
    03-26-2020 09:47 PM
  13. mustang7757's Avatar
    Sure I just showed someone how to do this here post #33
    Good you have some experience, also download samfirm latest tool for firmware
    https://forums.androidcentral.com/sh...d.php?t=997292
    03-26-2020 10:15 PM
  1. News Break app - cannot find to remove
    By teristark in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 05-22-2020, 09:13 PM
  2. Why is my S5 stuck on the logo screen after clearing cache?
    By AndroidNoob99 in forum General Help and How To
    Last Post: 03-30-2020, 12:11 AM
  3. galaxy fit e won't conect to phone
    By Unlimited Rice pudding in forum Samsung Smartwatches
    Last Post: 03-28-2020, 10:24 AM
  4. Replies: 8
    Last Post: 03-27-2020, 08:41 AM
  5. a number is constantly copied to clipboard
    By RoyCordero in forum Honor 8
    Last Post: 03-26-2020, 02:35 PM
