1. Alfawuf's Avatar
    I noticed constant data traffic on my Galaxy S9+ after Android 10 update. By constant I mean all the time the wifi indicator shows inbound and outbound traffic. Data usage meter shows several hundred MB of data, even overnight while not using the phone.
    So I deleted every app and reset to factory, Google account reinstalled apps after fresh boot after reset and the same thing.
    Is this normal? Have I been hacked? Dont know what to do.
    Rich
    03-31-2020 11:24 AM
  2. mustang7757's Avatar
    Hi , welcome
    Wifi could be used by apps while sleeping to update if you have automatically update on wifi or get notifications. Why would you think hack ? You seeing things rearrange on the phone any accounts been compromised ?
    03-31-2020 12:44 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! That's pretty normal. The system and other apps will often periodically refresh data in the background. You can get a better idea of what apps or services are using data in the Settings>Data Usage​ menu.
    03-31-2020 04:34 PM
  4. Alfawuf's Avatar
    Maybe I never noticed before, I dont believe I had ever seen this. The constant data transfer made me think I could not rule out being hacked some how. Tonight I am going to see exactly what happens. My router provides statistics on connected devices and shows total byte and packet transfer.
    04-01-2020 11:18 AM
  5. Alfawuf's Avatar
    OK, So with location, auto app update, wifi scanning all turned off my phone used 70 MB of data on wifi overnight, 8 hours. Way too much. Usage app showed almost all was Google Play Services. Why is it using so much data and constantly? How can this be stopped?
    04-03-2020 10:00 AM
  6. mustang7757's Avatar
    Google play services will always run on your phone regardless you turn this and that off which I don't recommend because when you need something or app tries to carry out a task your going be here for other issue . These things are completely fine on today's smart phone.
    04-03-2020 10:36 AM
  7. B. Diddy's Avatar
    70 MB these days is a drop in the bucket. If you have a severely limited data plan, or if you just want to limit the phone's web communication, then you could always turn off both wi-fi and mobile data before going to sleep.
    04-03-2020 03:12 PM
  8. BrianLightManBruce's Avatar
    Alternatively you may also disable WiFi for the App/Service. Go to settings —> Apps & notifications select the App in question. On the Apps property sheet select Mobile Data & WiFi. Disable/Deny WiFi Control by ticking the slider.
    04-04-2020 05:51 AM
  9. pontiac005's Avatar
    Or you can turn off the phone at night if 70mb really bugs you.
    04-05-2020 05:19 PM
  1. Blueft - files transfer among all Bluetooth devices for FREE!
    By melbon88 in forum Samsung Galaxy Watch Active 2
    Last Post: 05-19-2020, 08:56 AM
  2. Play store slow on mobile data, fine on wifi.
    By s4i1999 in forum Samsung Galaxy S10 & S10+
    Last Post: 04-06-2020, 10:44 AM
  3. Call and data at the same time
    By donebrasko in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 03-31-2020, 08:51 AM
  4. Does data use default automatically to WiFi?
    By EndRacism in forum General Help and How To
    Last Post: 03-30-2020, 09:49 PM
  5. Reload this Page TWRP issue...no data transfer
    By joncenawordlife in forum Xiaomi Android Phones
    Last Post: 03-30-2020, 05:01 AM
