battery drain
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
Your cell signal looks terrible in that screenshot -- is it often like that? Poor cell signal is a major contributor to battery drain.
msross
57
Thanks that might be the reason, Since I have lousy reception at my house and because of the pandemic....I am stuck here. Since I have wifi should I shut off the cell...will that possibly help while I am home
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
Yep, that's what I was going to suggest -- you could either turn off mobile data only and see how that goes, or turn on Airplane Mode and then turn wi-fi back on. Just make sure you have Wi-fi Calling enabled so that you can keep getting calls.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
Which carrier do you have? You could try calling their support and see if they offer free signal boosters for the home. I have one from T-Mobile.
msross
57
I am running with wifi only at my house and that seems to work.....getting 15 hours now. btw...I'm on the verizon network My house has a very week cell signal
Cy3berOdyssey
