A13 5g: Help with Accessibility Little Man functioning?
flycaster1
Active member
Aug 19, 2018
27
I had the little man set the way I wanted it to be, but, of course, as I try to learn the A13, I **bleep** up what I had wanted. So, please try to get me back to: When clicking the little man, I was able to toggle between two differently contrasted views of the present screen without any small screen being also being opened. After the first screw up, when selecting the LM, I somehow got a small screen that showed two items in it and nothing apparently happened. On the second screw up, when selecting the LM, nothing at all happens; no small screen, no change in anything. I'd like to get back to where selecting the LM, allows me to toggle between two differently contrasted screens. Thanks.
This the setting under interaction and dexterityView attachment 348112
Got to the menu, thanks. So, now I see that the little man button is the Accessibility Button (AB). However, when I activate it, it comes up with McAfee and Assistant Menu. Not bad, but not what I'm looking for. When I tap the button, I don't want to be brought to any apps or menus, I want to have the screen toggle between, as best as I can explain and was there at one time, two different contrasting screens. When I had this action, one screen had colors that were somewhat under-saturated, while the other screen's colors were saturated...thus the contrast which helped for better viewing under certain circumstance.
OK, I'm now getting somewhere with my quest. Although I can now get the two contrasting screens that I want, there still is a problem. But, first let me show how I get to those screens.
Settings>Accessibility>Visibility Enhancements>Color Correction=ON>Correction Mode (pick 1 of 3 choices)>Options>Color Correction Show (Accessibility Button)=ON.
So, with this setting, when toggling the AB, I now get a subscreen with McAfee, Assistant Menu, and Color Correction. Selecting Color Correction between ON and OFF does toggle the contrasting colors; however, I now need to delete both McAfee and Assistant Menu from the AB subscreen??? Thanks.
Glad you got some if it going, i dont use accesbilty menu enough to help customize it
If you go to advanced settings in accessibility, you can select what functions are available for the accessibility shortcut and the accessibility button.
You can also go to installed apps in accessibility and turn off individual apps.
Thanks, fuzzy, that's what I just found out prior to your excellent response. Yes, Advanced Settings held the answer. But, let me add a little something to the answer...may help others with similar problems. When I unchecked the two items I didn't want (but left Change Color checked) from the list of items available to the AB, and then selected the AB, the colors toggled and there was no submenu. So, bottom line, choosing more than one item will cause asubmenu to appear when selecting the AB.
stephenabord
