04-02-2018 06:42 AM
56 123
tools
  1. huma nauman's Avatar
    how much time does it take to get pass sign?
    03-20-2014 10:07 AM
  2. Gamal Eissa's Avatar
    Hi
    I recently Rooted my samsung galaxy s5570 mini, was having software problem so i installed a new software by program called "ODIN" the phone rooted fine then I shut the phone down then i pressed and hold power and volume down and home key I get zero response. Any help/direction would be greatly appreciated.
    04-17-2014 11:19 AM
  3. GSDer's Avatar
    Welcome to the forums!
    Have you tried taking the battery out and reinserting it?
    Does anything happen if you do a normal power on (just the Power button)?
    With the phone completely off, if you connect a charger do you see the normal charging activity?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Gamal Eissa likes this.
    04-17-2014 12:50 PM
  4. Gamal Eissa's Avatar
    thank you GSDer for your prompt reply
    yes
    no, just white light
    no
    04-18-2014 02:27 PM
  5. GSDer's Avatar
    The LED glows white? Or the phone starts to boot but only to an all white screen?
    If the phone won't boot into Download mode your options are pretty limited:
    1. purchase a JIG, which will force the device into Download mode if at all possible
    2. try loading a debrick image using an SD card (search for 'debrick' in these forums, not XDA or on YouTube - be sure it's for your model phone)
    3. use a JTAG service (ex. http://mobiletechvideos.mybigcommerc...-brick-repair/)
    04-19-2014 05:38 PM
  6. s3redlife's Avatar
    Hi guys I wanna know if it possible to update my Korean phone Samsung Galaxy s3 i9300
    GT-I9300
    android : 4.1.1
    baseban version : I9300XXALIH
    Build number : GINGERBREAD.ZSKJ6
    So can I update it to 4.3 or 4.2.2
    05-22-2014 11:45 AM
  7. akmal Hanna's Avatar
    how long does it take to flash note3 with odin?
    06-16-2014 05:42 AM
  8. GSDer's Avatar
    Odin should only take about ten minutes to flash firmware.
    06-17-2014 12:59 AM
  9. joem5636's Avatar
    It has been much more than 10 minutes... I tried to update my GT-N8013 to 4.4.2 and followed the directions to modify the .tar by deleting a few files. I re-tarred and then tried ODIN3.09 to update my pad. The only messages are:
    <ID:0/006> Added!!
    <ID:0/006> Odin v.3 engine (ID:6)..
    <ID:0/006> File analysis..
    <ID:0/006> SetupConnection..
    <ID:0/006> Initialzation..
    <ID:0/006> Get PIT for mapping..
    <ID:0/006> Firmware update start..
    <ID:0/006> SingleDownload.
    <ID:0/006> SS_DL.dll
    <ID:0/006> NAND Write Start!!
    Do I just continue waiting or what? (Luckily, I can leave this sitting.)
    09-13-2014 03:33 PM
  10. GSDer's Avatar
    I'd have to question any directions to remove files from the .tar file - that probably accounts for why Odin is hanging.
    You probably want to just flash the stock firmware.
    Golfdriver97 likes this.
    09-14-2014 03:55 PM
  11. Golfdriver97's Avatar
    I am inclined to agree with GSDer. I don't know any good reason to remove files from a .tar file.
    09-14-2014 04:01 PM
  12. vj10439's Avatar
    can you tell me what to do when it requires a PIT file? I have tried looking for this but it doesn't seem to want to complete the process without it.
    I have a Samsung S5 SM G900F.
    Thanks for any help.
    09-23-2014 04:08 AM
  13. GSDer's Avatar
    I have a Samsung S5
    You might want to start by looking in the carrier-specific sub-forum for your phone model. You're not likely to get a pointer to the PIT file for your phone in the S3 forums, since the PIT file varies by model, carrier and memory size.
    09-25-2014 03:34 PM
  14. Sarfraz Ahmed1's Avatar
    thank u very much
    10-01-2014 09:20 AM
  15. Joshoe's Avatar
    please assist as am trying to instal firmware for my samsung galaxy s2 GT-I9100 and this is the error am getting see attachment[Guide] Complete Guide to Using Odin(de-bloat,root and recover)-odin-error.jpg
    10-14-2014 03:26 AM
  16. GSDer's Avatar
    What led you to believe that you needed to load anything but the PDA file?
    10-17-2014 12:21 AM
  17. Alikay777's Avatar
    Hi, I did this information to flash my gt I9500 device. I did everything. but after reseting my device, the android robot ( the symbol) appears. it stucked. there is nothing to do. why this happens. please help me....
    12-21-2014 03:50 AM
  18. DibsXIII's Avatar
    Hi, my S3 crashed whilst showing a video, I had to take the battery out to reset it and hen when I turned it back on again it went into a boot loop and now it only comes up with a white screen when I turn it on. However I can still put the phone into Odin mode.
    After researching on the internet I downloaded Odin v3.09 and downloaded I9300XXUGMK6_I9300OXAGMK6_I9300XXUGMK6_HOME.tar.md5
    However, when I tried to run this, Odin came up with a fail message and reported that there was no PIT partition.
    Is the phone now a brick or is there a way of setting up the PIT partition using Odin? If there is a way of doing this, simple instructions (or as simple as possible would be much appreciated!!)
    Many thanks.
    01-27-2015 03:22 PM
  19. milo williamson's Avatar
    Okay with my .pit file, what option should I click after that?
    07-06-2015 12:34 PM
  20. Obi Eke's Avatar
    I get an error, a pit error... what should I do
    Tun AungKyaw likes this.
    08-10-2015 11:40 AM
  21. Ronald Halbal's Avatar
    can i flash another region's firmware on my Note 5?
    e.g. a N920i on a N920T (yes the N920T is unlocked)?
    I've read it was done but some minor bugs/errors were encountered after install.
    11-07-2015 10:26 PM
  22. cdiazr's Avatar
    Sorry but.. ¿Complete Guide to Using Odin? I don't think so... just flashing and that is only a toy for kids. Can you tell me how to set a new pit file in my phone? Why I have to? It is my business, just tell me if this post is a really Complete Guide to Using Odin.
    Thanks!
    12-28-2015 11:21 PM
  23. cdiazr's Avatar
    Don't spend your time, I found out how to flash de pit file successfully by my self.
    12-28-2015 11:52 PM
  24. djeowen's Avatar
    Thank you for this post - very helpful.
    My son's mobile (Galaxy 2 GT-I8160) was having issues connecting to play store. A number of forums recommended device resets, updates, clearing caches, uninstalling some apps. Reseting had no effect, the device said it was already updated, numerous apps including the ones I tried to uninstall showed zero bytes.
    I tried a flash of the device using up to date firmware and the odin software and it sorted it out a treat.
    I am aware of the dangers of bricking a device so I did this as a last resort.
    As I am the curious sort I will now play around with an old scrap device to get familiar with odin.
    Regards djeowen
    02-19-2016 12:13 AM
  25. brainox's Avatar
    I dont normally root devices but now that my s3 is old I thought why not, so thanks for the guide.
    03-26-2016 04:33 PM
56 123
