Save big + get 3 months free! Sign up for ExpressVPN today
  1. Flamer256's Avatar
    My dear S3, dies every six hours, no matter what i do, power saving mode spare a few minutes, but it is really annoying!!
    Just because lf this i have a portable charger/battery/emergenxy battery or whatever it's called so it survives until i get home from school.
    I can't post screenshots right now, but right now Android OS is at 28% , Android-System is at 12%, Google services at 9% and Screen at 6%. Five others are lower than 5%.
    Please help me :-)
    11-14-2013 03:22 PM
  2. Golfdriver97's Avatar
    Please help me :-)
    Have you tried to clear cache in recovery?
    Here is how: http://forums.androidcentral.com/sam...2-s3-tab2.html
    11-14-2013 05:42 PM
  3. Flamer256's Avatar
    Thanks for reply, but it's not working, it still dies after six hours.
    11-15-2013 04:54 AM
  4. megakony's Avatar
    get a big battery from Seidio or Mugen and your problem will be solved. There is no other way to help android with battery drain, at least I don't know one. I've tried every "save your battery life" trick there is on my Note 2 and it did not work until I got an extended battery
    11-15-2013 05:11 AM
  5. Flamer256's Avatar
    Okey, thanks for replying, gonna wish it for christmas :-)
    11-15-2013 07:30 AM
  6. Chiqx's Avatar
    There is a way to increase your battery life
    I also had this problem. Install Juice Defender Ultimate and Greenify. Your S3 will now live for 24 hours.
    11-16-2013 12:51 AM
  7. GSDer's Avatar
    It's possible that the battery is going bad - how long have you had the phone?
    Have you tried rebooting the phone?
    If you really want help with battery issues, there are three screenshots that you need to post from your battery stats:You could also try installing GSam Battery Monitor Pro: http://market.android.com/details?id...amlabs.bbm.pro (there's also a free version) and include a screenshot of the Phone Radio detail Finally, you can install Wakelock Detector: http://market.android.com/details?id...kelockdetector to see if you can identify what might be keeping the phone awake when it should be sleeping.
    Note that you'll want to fully charge the phone and then let it deplete to less than 40% before you gather those screenshots.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Golfdriver97 likes this.
    11-16-2013 08:26 AM
  8. Flamer256's Avatar
    I've got a very strange battery site....
    Right now it shows 100% Android OS and nothing else. I don't know how to add screenshots on this app...
    11-16-2013 01:31 PM
  9. Flamer259's Avatar
    I found out how, here you are:
    (Its Norwegian by the way)
    Do note:
    - The two dots of Charging (Lader) is my portable charger
    - I uninstalled two apps (Go Locker and App Locker) and have won about two hours of battery
    Sent from my GT-I9300 using AC Forums mobile app
    Attached Thumbnails S3 Battery Drain!!!-1384630561574.jpg   S3 Battery Drain!!!-1384630575097.jpg
    11-16-2013 01:36 PM
  10. Stags10's Avatar
    Sorry for the battery help, i know its been beaten like a dead horse but im desperate (desperate enough to maybe switch to iphone!) I fully charged my phone last night and have been sitting home with very light use and I've lost over 50% Connected to wifi and in very good service area. I'm stumped. I've closed everything and nothing is running in background. 4.1.2 on ATT
    11-16-2013 02:27 PM
  11. GSDer's Avatar
    Flamer259,
    1. There's definitely something jacked up with your data - there should never just be one item in the list. I assume that you actually used the phone to make calls, send messages, play games or surf the Web?
    2. Never charge the phone in the middle of a data run - it totally invalidates the time factor.
    3. The phone was awake more than the screen on time would warrant - you need to install Wakelock Detector and see if it can identify some rogue app that's keeping the CPUs from going into deep sleep.
    4. It may be time for a Factory Reset.
    11-16-2013 09:23 PM
  12. GSDer's Avatar
    Stags10,
    1. You didn't include all of the data requested - there's no screenshot of your Screen On time.
    2. You'll want to install GSam and use it to gather the Radio Detail - based on your expanded view I'd have to disagree with your assessment about being in a good service area: there's a big block of dingy yellow, indicating a marginal cellular signal, and even a block of black, indicating no cellular signal - that'll kill a battery like nothing else.
    3. Facebook - ugh! That app is nothing but trouble - look at the Google Play Store ratings if you don't believe me - it doesn't even score a 4.0.
    11-16-2013 09:32 PM
  13. Flamer259's Avatar
    Here is my battery page for today.
    And i am surprised, it lives much longer now, but still, take a look:
    Attached Thumbnails S3 Battery Drain!!!-1384721908971.jpg   S3 Battery Drain!!!-1384721920792.jpg   S3 Battery Drain!!!-1384721941410.jpg   S3 Battery Drain!!!-1384721967598.jpg
    11-17-2013 02:59 PM
  14. GSDer's Avatar
    I've never used Outlook on my phone, but that seems to be what's constantly waking your phone. You'll want to see if there's a setting in Outlook to decrease the polling interval.
    Facebook is also a lousy app, but don't take my word for it - just look at the ratings in the Google Play Store.
    Considering that you only had 1.5 hours of screen on time, I would have expected better battery life. Of course, you didn't start out at 100% charge. And mediaserver shouldn't have been chewing up that big a chunk unless you were streaming music/videos.
    Flamer256 likes this.
    11-17-2013 03:26 PM
  15. Ichi_Bear's Avatar
    I would get an OEM replacement battery or the official Samsung extended battery. I don't really have a problem with battery life right now. I use Facebook a bit and Twitter much more. Sounds like a rogue app is running in the background
    Sent from my S3 using Tapatalk
    Find me on Twitter @Ichi_Bear
    11-19-2013 02:23 PM
  1. Battery takes forever to charge?
    By prestonmiller91 in forum Samsung Galaxy Note 10.1
    Last Post: 07-11-2020, 07:54 AM
  2. Battery Drain While Phone is Off
    By rlakritz in forum Samsung Galaxy S4
    Last Post: 11-23-2013, 06:43 AM
  3. S3 won't turn on, no splash screen or charging indicator
    By sixhobbits in forum Samsung Galaxy SIII I9300
    Last Post: 11-20-2013, 12:09 AM
  4. Battery apps don't work on Kit Kat, N5
    By justlaxin13 in forum Google Nexus 5
    Last Post: 11-14-2013, 09:18 AM
  5. Samsung S3 all incoming calls are blocked, please help
    By Marfe in forum Samsung Galaxy SIII I9300
    Last Post: 11-14-2013, 12:51 AM
