[WARN]The rooting method in this thread is not compatible with the latest TouchWiz update. Please do not flash over TW until another method is found[/WARN]
So you've got your brand new shiny toy, and you're itching to rip into it and really make it your own... This is the simplest way I have seen yet to flash Clockwork Mod Recovery and root the Galaxy Tab 10.1. I did not create these methods or any of the tools necessary to accomplish this, I am simply passing along the information.
Credit for the CWM method goes to pokey9000 from XDA
Credit for the root exploit goes to pershoot from XDA
[WARN]I, nor Android Central, nor the people credited here take any responsibility for what you do with your device! Please read through each step before beginning, and if you are unsure of anything, ASK![/WARN]
Downloads:
[INFO]Before we begin, some basic information...
What does it mean to "root"?
Rooting an Android device gives the user "superuser" access, which means you're allowed to access system files which you normally wouldn't be able to otherwise. This allows for greater customization.
What is Odin?
Odin is a low-level flashing tool created and used by Samsung to flash the firmware onto their Android devices. It is a PC utility, so it is not compatible with Mac. You must have the Samsung drivers installed prior to flashing with Odin in order for the PC and Odin to recognize your device properly.
I have a locked Tab, will this work for me?
Yes! Fortunately, having a locked Tab still allows you to flash a custom recovery, which in turn allows you to flash ROMs, kernels, and other zips.
Can't I just use ROM Manager to flash CWM?
Unfortunately, you must be rooted in order for ROM Manager to function correctly. Without being rooted, you will not be able to flash CWM using that method.
[/INFO]
Downloads:
- Samsung drivers found here.
- Odin 3 v1.3 found here. Use an extracting utility to extract the .rar
- CWM found here
- Root tools found here
What is Odin?
[/INFO]
