1. PaulQ's Avatar
    I have the "power saver" feature turned off.
    When my Tab hits 15%, it will show the warning window. If I don't actually go and clear it, my Tab stays lit up. When I hit the power button to put it to sleep, it just turns back on in a minute or so. I have to go in and clear that warning window.
    Is that normal? Any setting I can adjust. If I'm not in the room to clear the window, it seems like it will just wear itself out more quickly by leaving the backlight on. Thanks!
    11-13-2011 10:58 PM
  2. anon(549921)'s Avatar
    What do you have set in the power save settings?
    11-13-2011 11:09 PM
  3. PaulQ's Avatar
    Nothing. I unchecked the top box ("Use Powersaving Mode") so everything else is greyed out.
    11-13-2011 11:21 PM
  4. anon(549921)'s Avatar
    Why don't you want the power save mode on?
    11-14-2011 08:59 AM
  5. PaulQ's Avatar
    I had a bad experience. I had this problem (screen stays on) plus, after I fully charged it, it didn't restore WiFi, screen timeout, and anything else I told it to adjust under low power. I had to manually turn everything back on, fix the timeout.
    It was just annoying so I turned it off.
    Unfortunately, this screen turning on situation happens regardless if you are using the Powersave Mode or not.
    11-14-2011 11:37 PM
  6. deaner1029's Avatar
    I'm sorry I can not help with this issue but I have the same problem. I constantly wake up and my gtab is dead because of this issue. Sometimes I'll wake up and go in the living room and the screen will be on for no reason at all.
    11-15-2011 12:06 PM
  7. anon(549921)'s Avatar
    Weird, I've left mine on all night and not had a problem before, although I usually put it onto charge over night. I have power save mode set to come on at 25% I think.
    11-15-2011 01:53 PM
