1. kaschiro's Avatar
    I ran out of title space..
    Question #1 The sound on my blue tooth (blue ant) is intermittent for the 1st 30 seconds,when I turn on the headset, then it clears up and is ok and everything is normal. So what I have been doing is turning on the unit and let it warm up for 30 seconds and then turn on the app and everything is fine. Is this normal???
    Question #2 how do I get/make a widget for this URL...I had it before...My unit was replaced and now I have to reinstall my apps...the url was sent to me and all I had to do was install it on my PC
    Can someone help me out
    Kas
    08-25-2013 03:18 PM
  2. rgarcia900's Avatar
    For #1 I use a bluetooth Plantronics stereo set and my car stereo, never had that issue.
    For #2 I never used such widget, but maybe someone else can chime in.
    Sent from my SAMSUNG-SGH-I497 using AC Forums mobile app
    08-26-2013 07:31 PM
  3. kaschiro's Avatar
    Thanks for the reply, Muchas gracias
    ...I have figured out how to get the widget ....!!!!
    of all the hits I thought someone has had a blue tooth problem like mine, any thoughts on this
    Kas (please do not take this personally, I do not want upset any body
    08-27-2013 12:24 PM
  1. Samsung Galaxy note 8.0 LTE international version unlocked ATT APN settings for go phone
    By Abhilash Nair in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 06-26-2014, 11:02 AM
  2. Advertisements on slide down notification
    By jc0187 in forum Samsung Galaxy S4
    Last Post: 10-24-2013, 06:39 AM
  3. How do I keep camera settings were I set them?
    By KootenyKid in forum Samsung Galaxy Note 2
    Last Post: 08-28-2013, 12:48 PM
  4. AndroidLost and gps
    Last Post: 08-26-2013, 03:27 AM
