1. John Dollosa's Avatar
    When I charge, and use it like a second or three, it will become 100%. Then I will shut downl then open it, it will show up a different battery %, then like after using it for like after i got example -4%, it will shut down as that my true battery percent is only 4%. I think this problems are caused because I am always using my tablet when charging. Thanks to all who can answer my battery problems.
    11-20-2013 05:53 AM
  2. John Dollosa's Avatar
    Please reply guys. I really need help.
    11-22-2013 06:32 AM
  3. rgarcia900's Avatar
    Turn the tablet off. Then charge it to 100%. See if it happens again.
    Try different charger and or usb cable. Use the oem charger and cable if you are not using them.
    If you still have a problem and are within warranty, I will exchange it.
    Sent from my SAMSUNG-SGH-I317 using AC Forums mobile app
    11-23-2013 07:54 AM
  4. rgarcia900's Avatar
    Also check your battery usage and see what is causing such drain. Might be an app or just failed hardware.
    11-23-2013 07:56 AM
  1. Samsung Galaxy S4 Active - Video too large to send, even 1 sec. Long videos?
    By Dwight Kuhl in forum Samsung Galaxy S4 Active
    Last Post: 03-20-2016, 06:12 AM
  2. Google Nexus 10 Tablet - cracked screen, need replacement help
    By lamenz in forum Google Nexus 10 Tablet
    Last Post: 12-16-2013, 10:16 AM
  3. Samsung Galaxy Note 3 - Turned off @ 100%...
    By bembol in forum Samsung Galaxy Note 3
    Last Post: 11-25-2013, 07:56 PM
  4. Samsung Galaxy Note 3 - Update did not fix distorted calls - please help
    By MichaelNote3 in forum Samsung Galaxy Note 3
    Last Post: 11-23-2013, 08:40 AM
  5. S4 Screenshot problems..click click click while talking??
    By wifflemaniac in forum Samsung Galaxy S4
    Last Post: 11-21-2013, 12:42 PM
