1. kojackjku's Avatar
    I noticed that when I switch to navigation apps, my radio app I use stops playing. Is there any setting to fix that?
    11-30-2019 04:45 AM
  2. Rukbat's Avatar
    Make sure it's not set to stop when it's not the foreground app. If you can't change that, use a different radio app - one that can play in the background.
    11-30-2019 12:52 PM
  3. B. Diddy's Avatar
    Also try the Android Auto app and see if the radio app can be used within the Android Auto interface.
    11-30-2019 02:05 PM
  4. kojackjku's Avatar
    My vehicle does not have android auto built in. does that matter?
    12-02-2019 05:19 AM
  5. L0n3N1nja's Avatar
    What phone are you using? It seems strange that the music stops while navigating.
    Which app is it?
    12-02-2019 08:51 AM
  6. B. Diddy's Avatar
    No, it doesn't matter -- I'm talking about using the Android Auto interface on the phone itself.
    12-02-2019 12:01 PM
  7. jbird68's Avatar
    I use drivemode instead of Android auto. Music will play while navigating. I don't have Bluetooth built in to my car. So I bought a Bluetooth to aux adapter and it works pretty well. Just have to turn down the volume before I turn off my car. Otherwise I'll get blown away by the radio when I start my car because the radio is the default source over the aux input.
    12-09-2019 01:57 PM
  1. How to check whether an APK File is safe or not?
    Last Post: 11-30-2019, 02:32 PM
  2. Replies: 3
    Last Post: 11-30-2019, 02:24 PM
  3. How to take off power off password
    Last Post: 11-30-2019, 12:20 AM
  4. Remove emoji app from phone
    Last Post: 11-29-2019, 11:22 PM
  5. Pop up playable ads keep appearing
    By Ellajoy in forum Ask a Question
    Last Post: 11-29-2019, 09:30 PM
