1. Kko 5's Avatar
    My 9 year old son uses the Galaxy Tab pro 10.1 for everyday gaming. Lately he has been complaining a lot that the battery drains out very suddenly while playing...example from 70% to 15% . And when i switch off the tablet for a while and switch it on again the battery goes up to 50%.
    Anyone has the same battery problems?
    05-20-2015 01:03 AM
  2. madankrishna's Avatar
    Its because if you operates many applications at atime or heavy memory applications then the tab goes to heavy load and your battery drains quickly thats why if you restart your tab it shows 50% battery.
    If you use normal apps without heavy loading then charging decreases gradually not instantly
    Kko 5 likes this.
    05-20-2015 02:57 AM
  3. Kko 5's Avatar
    Hmmm....Thanks a lot for the reply!
    Actually most of the times he plays heavy games and that might cause the battery draining fast.
    I will have a look at it based on your comments.
    Any other suggestions in order to remwdy this???
    05-20-2015 05:34 AM
  4. Beut's Avatar
    https://play.google.com/store/apps/d....bmw.pro&hl=en
    Install this application and using it to monitor your battery how much it drops after playing video for 1 hour.
    You may need a movie file which lasts around 1 hour or more. Good battery should drop only around 20% for playing video in 1 hour.
    A battery replacement may cost only around $30 but be sure it's bad. Sometimes, a bad battery connector may cause a quick discharge.
    If you know how to open this tablet, open and inspect the battery connector and slightly push it under magnified glass. If it's moving then it needs to re solder to fix the connection to motherboard.
    Kko 5 likes this.
    05-27-2015 08:08 PM
  5. Kko 5's Avatar
    Thank you Don Willy ☺
    05-30-2015 05:36 AM
  6. Beut's Avatar
    Inspect this battery connector first, replace new battery won't solve the problem if it's loose. It's very common in Samsung tablets.
    This is from Galaxy Tab 3 10.1 but it's similar to Galaxy Tab Pro 10.1 . If you don't know how to solder, a repair shop can do it but they cannot charge you much if they're told what to do and it takes less than 5 minutes. A good battery should not drop more than 20% with maximum settings after 1 hour of playing movie; this rule can apply for other Samsung tablets but you should expect less for smaller screen size.
    A quick test to verify that the battery connector is bad. Slap hard on the back cover near the center with your hand, it won't break the LCD but the tablet will shut down immediately if it has a loose battery connector. Battery's capacity readings go up and down are signs of bad or loose connector.
    Kko 5 likes this.
    05-30-2015 11:08 AM
  7. Christy Ferguson1's Avatar
    I have the same battery draining issues. my tab goes from a full or close to full charge to about 60% then drops to less than 10% in less than 15 minutes. could it be a bad battery? I have had my tab about a year and a half. Also, if you use it while charging it, will it cause this issue?
    09-18-2016 04:07 PM
  8. Beut's Avatar
    It seems the source of problem already mentioned many times but many users still believe it's from something else
    Read the threat 17 and 18, two persons actually know how to solder fixing the battery draining issue. It happens almost to every Samsung tablets, those have battery connector located at the center , the weakest point of a tablet.
    Battery FAST drain - Pg. 2 | Samsung Galaxy Note 10.1 (2014 Edition)
    The tab pro and Note 2014 are identical tablets except the Note has S Pen added to the LCD circuit.
    Syb Badger likes this.
    09-18-2016 10:11 PM
  1. Any lag or heating issues?
    By CPEjr in forum LG G Flex 2
    Last Post: 09-03-2015, 05:55 AM
  2. Anyone tried the ROCK Dot View for M9??
    By Cool Jeff in forum HTC One M9
    Last Post: 06-20-2015, 01:56 PM
  3. WiFi issues
    By Dperks17 in forum LG G3
    Last Post: 05-19-2015, 11:00 PM
  4. Replies: 1
    Last Post: 05-19-2015, 06:03 PM
  5. How can I fix my Lollipop draining my battery and issue with sms for S4?
    By mgrn2010 in forum Legacy Android & Other OS's
    Last Post: 05-19-2015, 04:31 PM
